Results 1 to 10 of 10
  1. Hi folks,
    May I get opinions, please?
    I currently convert all of my AVIs to MPG at maximum bitrate (9,800
    kbps). I then create a "DVD" using TMPGEnc DVD Author and then use DVD Shrink to reduce the files so that everything will fit on a single DVD-R.
    Would I be better off to determine appropriate bitrates in advance of conversion, so that I don't need to shrink the files? Is there a qualitative difference? Has any one here compared the two methods?
    Thanks!
    Roberta
    canada
    Best to calculate the bitrate as close as you can.No need to compare,shrinking will reduce quality if you need to reduce too much.
    May 2001
    Re-encoding always results in superior video.
    What's so hard about calculating bitrates?
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
  4. Always calculate the correct bitrate before hand. There are plenty of simple to use bitrate calculators to choose from. Use VBR for better quality.
    There are 10 kinds of people in this world. Those that understand binary...
  5. I thought DVDShrink only changed the bit rate and didn't re-encode, that's why it's so fast.
  6. Banned
    May 2003
    Massachusetts
    No no. DVD Shrink recompresses the transform data. The bitrate is part of the encoding, so there's no way DVD Shrink can touch it. You are producing a horribly wasteful and probably ugly to look at DVD with your method.
    May 2001
    Don't hold back now, Gurm! Tell how you really feel!
  8. Member daamon's Avatar
    Melbourne, Oz
    I'll second that. I've always found the VideoHelp Bitrate Calculator good.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  9. Banned
    May 2003
    Massachusetts
    I'm not trying to be mean, I'm just saying... ok lemme try to elaborate.
    You're making a HUGE DVD folder. Like 7 Gigs. It's so huge because the bitrate is high. Very little of that 7 Gigs is transform data.
    Then you're firing up a transcoder. The bitrate stays high, only you're trying to get a nearly 50% shrink out of the transform data. There just ISN'T enough transform data to work with, I'm amazed that Shrink would even let you make it small enough to fit... and the outcome would likely look TERRIBLE since you're squeezing that transform data so tight.
    On the other hand, using the lower bitrate... well, let's be honest - your AVI file didn't have 9800kbps bitrate, did it? Pick a reasonable bitrate to make it fit, and you'll probably find that it's STILL more than enough, and you get to keep all the transform data.
  10. Well, it certainly looks like there's a concensus!
    Thanks!
    Roberta
    P.S. DVDs compressed using DVD Shrink don't look terrible. I just never bothered to compare "shrunk" ones vs. calculated ones. I just may do that.....
