I'm trying to create subtitles with Subtitle Workshop. I saved my DVD onto my hard drive, and opened the last .vob file since I want to put the subtitles on video which is at the end of my disc. But Subtitle Workshop doesn't seem to want to work with all of the video - after 6 minutes the timer stops but the movie still plays... I also have a few reliability problems with the Movie playing... I tried the coda codec pack but this didn't help.
Am I doing something wrong here - such as trying to play .vob files ? Can I convert these .vob files into some other format that Subtitle Workshop is happier with?
Thanks for any help !
One thing I found out about Sub workshop is that it doesn't change idx into srt... it doens't even load idx/sub files..
They really need a newer version.
hi
i would convert the last vob to divx and load the divx file into SW.
works for me -
a while ago i tried to make subtitles for a dvd i had without subtitles i bought abroad. the ones i found on the net were badly translated so i set on to making a some by me.
first i copied the dvd to hd but without splitting the vobs in 0.99g chunks, then i loaded the vob on to subtitle workshop but it didnt play properly. i checked wich other formats SW supported and divx is one of them so converted the whole movie to divx and done that way
only convert your last vob to divx and youre away. -
you can use virtualdub mod or dr divx to only convert convert the last vob.
use the trial o dr divx and select the portable video profile to make a faster conversion
Frustrating Problem! Subtitle Workshop Won't Play Videos, Noticeably, AVIs!
By justforthis,maybe in forum Newbie / General discussionsReplies: 6Last Post: 22nd Jan 2012, 07:12 -
Problems with Subtitle Workshop
By Maurob67 in forum SubtitleReplies: 2Last Post: 7th Jun 2010, 03:42 -
dvddecrypter to vob files to avi problems with subtitle
By carlos28355 in forum Newbie / General discussionsReplies: 17Last Post: 19th May 2010, 06:33 -
By Jomapil in forum Newbie / General discussionsReplies: 2Last Post: 20th Jan 2009, 16:17 -
Problems with timing using Subtitle Workshop
By Antus77 in forum SubtitleReplies: 1Last Post: 24th Jun 2007, 21:27
