Hey. This is my first post to this forum
I have a problem with playing certain DIVX movies. When using WMP 7.1, it doesn't recognize the format of these movies and fetches a codec from a website. It then shows the movie but without sound. The Playa doesn't fetch a codec but shows the movies with no sound also. Other DIVX movies which WMP 7.1 recognizes the format of and therefore doesn't fetch a codec, work of course.
Hope you can help me!
John
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
try to find the Tsunami Filter Pack and the DivX codec 4.1x pack
install them both
if you still don't have any sound, than I can't explain either.
I've seen an answer for this here. Do a forum search on "no audio" and I'm sure you'll find it.
Liz -
Problem solved...thnx for the replies
I downloaded the Kristal Studio Pack and installed it.
One of the codecs were the right one, 'cause now playback works.
John
Surround Sound in Movies
By therock003 in forum AudioReplies: 36Last Post: 1st Jun 2012, 05:50 -
No sound on movies, only background
By N3kr0 in forum Media Center PC / MediaCentersReplies: 1Last Post: 19th Jul 2011, 17:21 -
Sound Levels when playing Movies
By zenzen1 in forum AudioReplies: 3Last Post: 4th Feb 2010, 22:40 -
Poor sound from DVD movies
By ranchhand in forum AudioReplies: 11Last Post: 31st Dec 2008, 18:58 -
Does removing DTS sound in movies help Dolby?
By JohnnyBob in forum AudioReplies: 22Last Post: 11th Sep 2007, 15:53
