Page 2 of 2
FirstFirst 1 2
Results 31 to 32 of 32
  1. i think i have a corrupt mgp or something. the file size is 200mb yet after vsodivxtodvd is done its only like 5 minutes long so im working on fixing the mpg right now yet gspot claims it is a asf or wmv...ill get back with ya as soon as i know
    Apr 2003
    Maryland
    Remember that vsodivxtodvd is for converting AVI namely Divx to DVD format ( AUDIO_TS and VIDEO_TS ) Not menus, files will will simply play one after the other in you DVD player, set top or otherwize. Although you can use your NEXT button to jump forward from one file tho the next as well as backwards. If you want a menu, you can "extract" each .VOB to MPG ( VOB if an MPG anyweay but ,,,,) in TDA and you can then add chapter points and create a menu for them. You can then output once again to DVD files and folders and burn back to DVD-r. This will provide you with a set of movies and a nice menu structure to navigate though. It all depends what you want. vsodivxtodvd will give you an instant dvd but not menus and TDA will produce menus but at the cost of extra work and time. With as many files as you say you have, you might just reach old age by the time you are done. Good luck any way.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
