Hello All..I've tried to find an answer to this with no luck so I'm hoping someone can help. I have an AVI file that when played on my Philips DVP642 has no audio. G-Spot says the audio is encoded as...
"0x0055(MP3) ID'd as MPEG-1 Layer 3"
...and it plays fine on my PC.
So....I used Virtual Dub to extract the audio as a Wav file thinking I can Re-Encode it and fix the problem.
I set VirtualDub to Direct Stream Copy for the Video, Full Processing for the Audio, Selected the WAV file I'd extracted...BUT !!!! when I select MPEG Layer 3 as the Compression format and check the box "Show all Formats" the BEST rate available is only 56Kb/s, 24Khz Stereo. A FAR cry from the typical (looking at other AVi files) 128Kb/s 48Khz Stereo.
Am I missing SOMETHING? I've never had a problem playing any AVI's on my PC so I can only ASSUME I have all the appropriate codecs installed. I tried using a different Filter (CCITT u-Law 94Kb/s 48Khz Stereo) and the file wouldn't play at all on the Philips.
Any and ALL help will be GREATLY appreciated.
Cheers....Dean.
install lame mp3 acm and you can select lame mp3 in virtualdub...using any bitrate.
Thank you Baldrick !!! In fact while waiting for a reply I did just that. I got the "Lame" hint from a Tutorial I found while searching.
SAD thing is...Encoding went well, VirtualDub had no complaints, the file STILL plays fine(audio and video) within Windows Media Player, yet the Philips WON'T play it. It plays the original fine (with no audio though) but the re-encoded version is ignored. I made sure I used "Direct Stream Copy" so as to not mess with the Video stream but I'm guessing the Philips doesn't like the "Lame" audio encoding. I'm going to try a different file that plays perfectly (audio and video) to see if it will play after re-encoding the audio with Lame. That'll determine if Lame is the problem or something else.
Any further thoughts though anyone ???
Cheers....Dean. -
I'm using Lame Version 3.96.1
To update...I read somewhere to resave the AVI using AVI OLD format (within Virtualdub) and that didn't help either. Now I'm re-encoding the Entire file (both Video and audio) hoping THAT might help.
Very strange ????
Dvd to .avi audio problem
By gartzo in forum Video ConversionReplies: 5Last Post: 21st Feb 2012, 09:04 -
extract avi audio problem
By gibkho in forum AudioReplies: 8Last Post: 13th Jun 2010, 13:18 -
.mov to .avi problem - no audio
By nagel in forum ffmpegX general discussionReplies: 2Last Post: 11th Oct 2008, 09:14 -
Avi to Divx audio problem
By win993 in forum Video ConversionReplies: 4Last Post: 25th Sep 2008, 17:53 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22
