hi i am using dvd2svcd and authoring with tmpenc dvd author,to convert some home videos,which are in avi format to a disc with a menu , out of the 7 clips 3 are out of sync . also can i use the multiplexed file for the audio? why do conversions go out of sync? also what is multiplexing??
https://www.videohelp.com/glossary?M#Multiplex
what it is your source? home video? dv avi?
what kind of out of sync? does it get worse or is it the same the entire clip?
what encoder are you using with dvd2dvcd? tmpgenc? -
hi the source is avi - i converted analoge home movies to microsoft avis, using adaptec videoh! cd the clips are between 1 minute to 7 minutes long,the out of sync doesnt seem to get any worse,its about 1-1.5 seconds out of sync yes i am using tmpgenc encoder and authoring with tmpgenc dvd author i am just trying again as i have used virtualdub to convert the sound to wav hopefully this will work??
no it did not work looking again its 2 seconds out of sync- why are the other clips fine??
ripped dvds when converted to avi out of sync
By angryassdrummer in forum Video ConversionReplies: 3Last Post: 9th Jan 2012, 07:43 -
Multiplexing Issues (mp4muxer 0.9.3)
By JuddM in forum Video ConversionReplies: 4Last Post: 19th Jan 2011, 06:00 -
Fixing / Determining Audio Sync Issues With Only Some DVDs
By TheNut in forum DVD RippingReplies: 5Last Post: 12th Dec 2009, 18:47 -
Why do i always get out of sync dvds?
By mrjust in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2009, 19:36 -
VOB multiplexing
By atulbha in forum Authoring (DVD)Replies: 8Last Post: 24th Jul 2009, 16:52
