A video camera is on an aircraft, recording perpendicular to earth. The film then shows a slowly moving earth (sometimes it shakes a little). The camera output is 525lines interlaced (60 fields per sec. / 30 frames per sec.). The film looks quite good.
My problem:
I need only one optimized image nearly every 2 seconds.
At the moment I record the output with a S-VHS recorder (not the best idea, I know). After recording I capture frames every 2 seconds from VHS tape (Hauppauge WinTV Theater). These frames show interlaced comb effects, because objects are moving (ca. 10m between 2 fields). To have a better result I deinterlaced the single frames with a virtualdub plugin (different ones tested). Due to deinterlace I loose resolution, thats bad.
Would it be possible to capture single fields every 1/60 sec and then overlay 2 fields (after motion compensation)?
Or what else would be a good idea for one optimized image? May be some averaging with multiple frames/fields?
Thank you
Frank
You won't be able to really get rid of the interlace effects with your current camera, and I don't think you'll ever be really happy with motion compensation on that video.
What you need is either a better video camera, or a digital still camera, or a regular film camera.ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W
Need a video camera soon
By jabbo5150 in forum MacReplies: 9Last Post: 3rd Dec 2011, 19:41 -
RIP Video of unfinalized dvd from Video Camera
By burnbrain in forum DVD RippingReplies: 8Last Post: 11th Apr 2011, 11:01 -
converting video camera to my pc
By m7cdc2 in forum Newbie / General discussionsReplies: 5Last Post: 24th Dec 2010, 15:44 -
SD Video Camera Vs. HD Movie Mode on Digital Still Camera.
By CP/M User in forum Newbie / General discussionsReplies: 20Last Post: 20th Nov 2009, 14:57 -
recording from more than one video camera
By wingdude in forum Newbie / General discussionsReplies: 3Last Post: 11th Sep 2008, 23:31
