I tried to convert an AVI with RC9 and it had not problems. I then installed the RC9b and had the following messgae appear and the software just stopped....
Version:SVCD2DVD 2.0 RC9b
Type: System.NullReferenceException
Source: SVCD2DVD
Message: Object reference not set to an instance of an object.
InnerException:
StackTrace: at x3284ccece41ee22b.xd3764d4f1e921081.x3b9d134dac76e 484(xece14591aa1abb99 x50afe96f7df19242, xcbd1127f90d7945f x3146d638ec378671)
at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
at x3284ccece41ee22b.xd3764d4f1e921081.x12cbe7a4e46ac 9ae()
Please advise..
Can you email me your log file please? I will take a look.
Ok. Thanks for the headsup. I have issued a fix - can you redownload?
hi chrissyboiy
got this from my JIT today. Have rc9b installed:
Informationen über das Aufrufen von JIT-Debuggen
finden Sie am Ende dieser Meldung, anstatt in diesem Dialogfeld.
************** Ausnametext **************
System.NullReferenceException: Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt.
at CodeLock._Secure.Register()
at AxCodeLock.AxSecure.Register()
at x3284ccece41ee22b.x2f5590cb48bb0c53.xfd572aadccf2a eb0(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.Windows.Forms.Form.OnActivated(EventArgs e)
at System.Windows.Forms.Form.set_Active(Boolean value)
at System.Windows.Forms.Form.WmActivate(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.ControlNativeWindow.OnMessage (Message& m)
at System.Windows.Forms.ControlNativeWindow.WndProc(M essage& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Geladene Assemblys **************
mscorlib
Assembly-Version: 1.0.5000.0
Win32-Version: 1.1.4322.2032
CodeBase: file:///c:/windows/microsoft.net/framework/v1.1.4322/mscorlib.dll
SVCD2DVD
Assembly-Version: 2.0.1955.34642
Win32-Version: 2.0.1955.34642
CodeBase: file:///C:/Programme/CD-DVD/SVCD2DVD%202%20BETA/SVCD2DVD.exe
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms/1.0.5000.0__b77a5c561934e089/system.windows.forms.dll
System
CodeBase: file:///c:/windows/assembly/gac/system/1.0.5000.0__b77a5c561934e089/system.dll
System.Drawing
CodeBase: file:///c:/windows/assembly/gac/system.drawing/1.0.5000.0__b03f5f7f11d50a3a/system.drawing.dll
AxInterop.CodeLock
Assembly-Version: 1.0.0.0
Win32-Version: 1.0.0.0
CodeBase: file:///C:/Programme/CD-DVD/SVCD2DVD%202%20BETA/AxInterop.CodeLock.DLL
Interop.CodeLock
CodeBase: file:///C:/Programme/CD-DVD/SVCD2DVD%202%20BETA/Interop.CodeLock.DLL
mscorlib.resources
Win32-Version: 1.1.4322.573
CodeBase: file:///c:/windows/assembly/gac/mscorlib.resources/1.0.5000.0_de_b77a5c561934e089/mscorlib.resources.dll
System.Windows.Forms.resources
CodeBase: file:///c:/windows/assembly/gac/system.windows.forms.resources/1.0.5000.0_de_b77a5c561934e089/system.windows.forms.resources.dll
AxInterop.SHDocVw
Assembly-Version: 1.1.0.0
Win32-Version: 1.1.0.0
CodeBase: file:///C:/Programme/CD-DVD/SVCD2DVD%202%20BETA/AxInterop.SHDocVw.DLL
Interop.SHDocVw
CodeBase: file:///C:/Programme/CD-DVD/SVCD2DVD%202%20BETA/Interop.SHDocVw.DLL
System.resources
CodeBase: file:///c:/windows/assembly/gac/system.resources/1.0.5000.0_de_b77a5c561934e089/system.resources.dll
Accessibility
CodeBase: file:///c:/windows/assembly/gac/accessibility/1.0.5000.0__b03f5f7f11d50a3a/accessibility.dll
RegistrationSDK
Assembly-Version: 1.0.1608.40231
Win32-Version: 1.0.1608.40231
CodeBase: file:///C:/Programme/CD-DVD/SVCD2DVD%202%20BETA/RegistrationSDK.DLL
System.Xml
CodeBase: file:///c:/windows/assembly/gac/system.xml/1.0.5000.0__b77a5c561934e089/system.xml.dll
System.Security
CodeBase: file:///c:/windows/assembly/gac/system.security/1.0.5000.0__b03f5f7f11d50a3a/system.security.dll
************** JIT-Debuggen **************
Um das JIT-Debuggen (Just-In-Time) zu aktivieren, muss in der
Konfigurationsdatei der Anwendung oder des Computers
(machine.config) der jitDebugging-Wert im Abschnitt system.windows.forms festgelegt werden.
Die Anwendung muss mit aktiviertem Debuggen kompiliert werden.
Zum Beispiel:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
Wenn das JIT-Debuggen aktiviert ist, werden alle nicht behandelten
Ausnahmen an den JIT-Debugger gesendet, der auf dem
Computer registriert ist, und nicht von diesem Dialogfeld behandelt.
and here is another one:
Version: 2.0 RC1 (and also RC6 & 9 -> same fault)
Type: System.ArgumentException
Source: System.Drawing
Message: Font 'Arial' unterstützt nicht das Format 'Regular'.
InnerException:
StackTrace: at System.Drawing.Font.Initialize(FontFamily family, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet, Boolean gdiVerticalFont)
at System.Drawing.Font..ctor(String familyName, Single emSize, FontStyle style, GraphicsUnit unit, Byte gdiCharSet)
at x3284ccece41ee22b.xddb8d1ea6c9958c7.xc27a5e273f5e7 c56()
at x3284ccece41ee22b.xddb8d1ea6c9958c7.x20aee28197748 0cf()
at x3284ccece41ee22b.xddb8d1ea6c9958c7..ctor()
at x3284ccece41ee22b.x210ff09a2516b1a7.xc456b78441ff1 c49()
at x3284ccece41ee22b.x210ff09a2516b1a7.x0507e45eec4e9 097(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at System.Windows.Forms.Control.set_Visible(Boolean value)
at System.Windows.Forms.ThreadContext.RunMessageLoopI nner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.ThreadContext.RunMessageLoop( Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(Form mainForm)
at x3284ccece41ee22b.x210ff09a2516b1a7.xc447809891322 395(String[] xce8d8c7e3c2c2426) -
ok. The last error points to a corrupt .net framework. The first to a dll not being registered.
recomended cause of action:
1. Uninstall SVCD2DVD 2
2. Apply .net 1.1 sp1
3. reinstall the latest SVCD2DVD from the website.
Let me know how you get on.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
hi chrissyboy
thx for ur fast help.
i had .NET 1.1, but i checked it today and have noticed, that some files were corrupt. had to reinstall it and now it works.
greez
weed
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
