I am trying to capture with Virtualdub from my VCR. It does not see it. In fact it see my webcam. Tried to turn it off and all webcam softwares it did not help.
With the same connections thaugh, I am able to use Windows Media Center and Click to DVD.
Any suggestions would be greatly appreciated.![]()
Results 1 to 12 of 12
It never will be able to see your VCR, but it should be able to see the capture device you are connecting the VCR to. Need a bit more information to be able to help.
Virtualdub use vfm capture drivers and your equipment use wdm capture drivers.
Try the other alternative for capture: VirtualVCR -
I have a Sony Vio that has windows media center for windows xp. It comes loaded with softwares like click to DVD and DV gate.
By the way, I dowloaded smart vcr. Screen remains white and does not pick up the VCR. -
Originally Posted by SatStorm
the newer version(s) of VirtualDub will use WDM drivers just fine"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
Virtualdub still use warpers to handle wdm on later versions. Those "experimental" versions, don't work on anyone without problems!
La Linea by Osvaldo Cavandoli
I guess I'm not anyone then...
anyone, everyone
I always mess those too words (English is not my native language) -
either way, you are generalizing.
I capture with with VirtualDub using WDM drivers with no problems.
jimmalenko makes a very good point
how is your equipment connected? I'm assuming that your webcam is probably USB, just unplug it.
How is your VCR connected to your video card?
What kind of video card do you have?
Filling in your Computer Details on your forum profile would keep ppl from having to ask..."To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
On General Questions, you Get a General Answer
You don't answer with questions.
We have a different approach and your irony is not appriciated -
yadoc being you have MCE you have Hardware MPEG Encoder so there for it not going to work with VirtualDub.
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 00:54 -
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 22:33 -
Device Capture - USB, Works With PAL / NTSC, Works with VirtualDub/VCR
By Drazick in forum Capturing and VCRReplies: 0Last Post: 7th Aug 2010, 18:27 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
Best VCR OR VCR/DVD COMBO for restoration
By demonwarrior in forum Newbie / General discussionsReplies: 7Last Post: 24th Aug 2007, 02:02
