I am new to DVD writers. Please help me. I installed 2 optical drives on my PC.
Drive D : Lite On Combo CD-WR & DVD ROM 5232 (read only), set as
master.
Drive E : Pioneer DVR-109 set as slave
and both drives are working fine (devices shown working properly in Device Manager).
After I install Nero software, I don't see Drive E: anymore ! In system dianostics, I saw Drive E : Pioneer DVR-109 with the yellow exclamation.
Below it said : "the device is not connected to the system"
Is there something wrong with my set-up ? How can I make Drive E:
work like before. Thank you for your help.
Andy
could be aspi, try reinstalled nero, if that don't work go to adaptec and download there aspi , but don't get 4.71 get the 4.70 or whatever there newest one causes more problems.
What other burning software did you have installed?
What other software did you remove?
Might be your upper and lower filters got messed up (Easy CD Creater) search google -
I removed Roxio Creator 5.
Installed Roxio Creator 6, Clone DVD, Any DVD.
However, problem is ON and OFF. Sometimes PC recognizes drive E:\ by itself. Problem occurs only when I install any new burning software. I unplugged DVD burner from IDE cable, pui it back, and restart PC and it's OK. Do you know what has caused this ? Thank you for letting me know.Andy
Software not installing in English
By beavereater in forum ComputerReplies: 3Last Post: 2nd Feb 2012, 10:48 -
VBScript runtime error when installing Perrla software
By budz in forum ComputerReplies: 7Last Post: 27th Aug 2010, 03:53 -
problems installing add'l software for ffmpegX: mencoder
By Tomtom2011 in forum ffmpegX general discussionReplies: 2Last Post: 2nd Apr 2010, 18:47 -
Question why un-installing 1 software knocked out 3 other softwares
By jimdagys in forum ComputerReplies: 6Last Post: 25th Sep 2009, 22:50 -
Software fails to recognize DVD-RW discs
By Mummyscurse in forum DVD & Blu-ray RecordersReplies: 8Last Post: 24th Oct 2008, 17:07
