heres my problem:
i'm trying to make a multi-movie dvd. i converted the two xvids using divxtodvd (i played the vobs...flawless as usual)
then i loaded the video_ts folder into TMPGEnc DVD Author so i can make a menu for my multi-movie dvd. it loaded up all fine. i created the menus and after it was done authoring, the audio was out of sync/the video was lagging/stuttering
TDA doesn't reencode and the divxtodvd files were perfect so what happened in between? the usual response is the "audio wasnt 48 khz" or "the framerate was different for the two movies" but divxtodvd corrects all that and makes them into the standard dvd format, correct?
menus are kind of important when making these kinds of dvds so i really need ur help here!
(btw...i tried this using two completely different xvids...same result, i've tried ones with mp3 audio and ac3 audio, again same result...also, i tried winavi converted vobs, and same problem)
well i prefer the others just because of the speed
tmpg takes more than twice as long to process for the same quality output...i used to love tmpg and i still do, i just wish it was faster!
i may go with tmpg but does anyone know any solution to the problem i'm having now?
thanks again
Need help with sync problems during processing
By Jon.G in forum Authoring (DVD)Replies: 23Last Post: 6th May 2011, 05:14 -
Issue with Xvid audio sync after YouTube processing
By brassplyer in forum Video Streaming DownloadingReplies: 1Last Post: 2nd Jun 2008, 05:59 -
VIDEO_TS with audio out of sync
By Levina in forum MacReplies: 8Last Post: 7th May 2008, 13:25 -
Need Assistance With TDA 3 Audio (and or Audio Settings)
By isamudysan in forum Authoring (DVD)Replies: 0Last Post: 4th Mar 2008, 22:41 -
reauthoring TDA video in TDA throws audio off
By spiritgumm in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 19:04
