Hi, I just got a miniDV camcoder and is ready to capture my first video with Ulead VideoStudio9. There are several capture options available including capture as DV or DVD. I plan to convert my video to DVD. How should I capture my video as DV-1 or DVD. Thanks for your help.
Hi alexasha,
DV AVI is much better suited to editing, but will require encoding (by Ulead I guess) at a later stage for DVD.
Capturing to MPEG (which, I'm guessing, is what'll happen if you choose DVD) will be quicker coz there'll be no, or minimal, encoding required before authoring to DVD - but the quality may be less.
Whether the loss in quality is noticeable or imprtant - only you can decide.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Originally Posted by alexasha
Ulead Studio 9 also has realtime MPeg2 (DVD format) mode as well. It works if you have a relatively fast computer (>2.4GHZ). It will run your CPU up to 70+% and may buffer. Buffering does not necessarily mean it's loosing frames. Run some tests first before you rely on it. Quality will be less than the technique above but does speed the process for applications like TV capture. Editing will be more coarse in MPeg2. Also any higher compression than 7,000Kbps VBR + MP2 audio will take a much faster CPU. -
Thanks for the input. I understood that capture as DV-1 with capture video and audio in two separate files. DV-2 will capture both as one. I am more interested in quality video but my audio (comment) would not require high quality. Am I right to assume that it would be easier to capture as DV-2?
Again, thanks for the help -
Originally Posted by alexashaGeorge
Ulead Video Studio better than VDub for capture?
By trickymcgee in forum Capturing and VCRReplies: 7Last Post: 17th Apr 2012, 18:22 -
No sound on ULEAD Video Capture
By bagshot48 in forum Newbie / General discussionsReplies: 8Last Post: 17th Oct 2008, 10:18 -
video capture problems in ulead videostudio 11
By scott114 in forum Newbie / General discussionsReplies: 0Last Post: 23rd Jul 2008, 15:49 -
dv/ulead capture, aspect ratio problem
By Statick in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 5th Jan 2008, 15:46 -
Problems with Videostudio9
By Tamberam in forum Newbie / General discussionsReplies: 8Last Post: 11th May 2007, 00:01
