RIght now I have a radeon 9500 pro. I am wanting to get my vhs recordings to my computer so I can burn them to dvds. Is buying a new video card the best thing to do or can I buy something else cheaper? also what kind of cable do I need to connect the vcr to pc?
if it matters I have an audigy 2 zs video card
If u bought this new, it should have all the cables u need in the box. If not, then i suggest u go to a store that sells this sorta stuff, and they'll help u out.
I recently got a 9200Radeon, and everything i needed was in the box.
btw, does "zamac_man" mean u r into hotwheels cars?you say Y,
I say Y not? -
I used to be into hotwheels. I started collecting in 98 when the zamacs where at the convention. I look every now and then.Originally Posted by montburnsy
I will look for cables -
That card does have a video 'in' jack? I thought the 9500 Pro was only a display card?
I think you might be right. If I hook up the vcr to the s-video while on output it won't do anything, right? What do I need to buy that is cheap?Originally Posted by redwudz
how would this work?
http://www.newegg.com/Product/Product.asp?Item=N82E16814102492 -
"All In Wonder" = graphics + video
no "All In Wonder" = no video, just graphics
Need this:
are you saying I can buy ^ and hook it up to my video card? or saying that I need to buy an AIW card?Originally Posted by lordsmurf
If I need to buy that how much and where can I? -
Non AIW won't capture any vdeo, they are output only. You either need to get the AIW version or buy a separate TV card like ATi TV Wonder.
I've had TV Wonder Ve for a number of years with only one major problem, way back when Windows XP was new and ATi was slow in getting XP compatible driver out. I generually use VirtualVCR with the TV Wonder VE and used Huffyuv and haven't had any problem getting the capture at all, not even a dropped frame
Using an Onboard video card with a PCI video card
By Nastydave in forum Media Center PC / MediaCentersReplies: 3Last Post: 6th Apr 2012, 03:37 -
[VHS conversion] Sound Card, Video Card?
By bessiecat in forum Capturing and VCRReplies: 6Last Post: 26th May 2011, 14:02 -
Looking for new driver for video card- MEDION (7134) WDM Video Capture card
By 2prfm.com in forum Capturing and VCRReplies: 3Last Post: 15th Sep 2008, 03:48 -
Do I need a Video Card or a Capture Card...
By gnomeChomsky in forum Capturing and VCRReplies: 14Last Post: 18th Jan 2008, 22:26 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
