Hi guys,
I'm a DVD-Rip enthusiast who is trying to make a backup of all his favorite DVDs to VCDs. For the past week or so, I have been using DVD2AVI and TMPEG to encode the Sleepy Hollow DVD to VCD format. I used the normal VCD NTSC template that came with TMPEG and set the motion search to highest (very slow). Overall the result was quite good with the exception of some really apparent noise blocks in certain scenes (such as in the forest where the leaves start to fall).
Now I understand that it is possible to "tweak" or alter the settings in TMPEG so that a better quality video maybe obtained. Is there anyone out there who can help share with me the ideal setting for VCD encoding in TMPEG so as to obtain a better quality than the one I already have?
Note: I use a VCD player at home so XVCD and SVCD are out of the question. I'm just thinking of tweaking the current NTSC FIlm VCD default template in TMPEG so as to get a really good result. So to all the experts out there, care to share what settings you use to make a really good quality yet compliant VCD? Any posts and feedback will be much appreciated.
Happy Holidays
And warmest regards to all
FARINAZ
Results 1 to 1 of 1
Optimizing Settings for youtube upload like fast start etc for x264 encoder
By vibes992000 in forum Video Streaming DownloadingReplies: 2Last Post: 6th Feb 2012, 00:30 -
Attn: HC Encoder Experts/Optimized Settings?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 0Last Post: 7th Nov 2011, 22:11 -
kmttg +encoder settings
By Danneauxsvh in forum Video ConversionReplies: 2Last Post: 4th Jan 2011, 16:38 -
hc encoder profile settings
By bmwracer in forum Video ConversionReplies: 12Last Post: 28th Feb 2008, 17:46 -
change dimensions easily, and encoder settings?
By ChillBill in forum EditingReplies: 3Last Post: 12th Aug 2007, 14:49
