ever dvd has an intro title where right b4 the menu is shown u see a short video sequence of what the series or movie is about, how do i go about ripping that lil intro video and convertin it to a mpg or avi video file? i can't seem to find it thats the thing also
Results 1 to 15 of 15
Try DVDSHRINK, this will allow you to see all the seperate parts of a DVD structure.
You can find the part you want by opening up the files one by one and previewing them.
Once you find the part you want you can back it up on its own to a video file (You need to do this in the re-author window) and then use one of the other software tools on here to convert it to what you want.
I use DVDSHRINK to rip the Dolby trailers and other such trailers to use on other DVD,s.
Check out the guides and you'll find some useful ideas for how to do this.
Good luck -
DVD Decrypter in IFO mode.
Originally Posted by BIFFtheSTIFFWant my help? Ask here! (not via PM!)
I'd use IFOEdit's DVD Player, because whilst playing it shows you which title and which chapter it is playing, and then also once you're finished, it gives you a messagebox with a list of titles that it played. Makes it easy to see the order in which things play.
DVDShrink's preview would work OK also, but I think my suggestion is a more direct way of doing it.If in doubt, Google it. -
ok here's the thing, i tried dvdshrink and found what i was lookin for, but how do i rip only that file? when i tried lookin for it in dvdecrypter it doesn't find it and i tried the file mode and ifo mode and nothing it doesn't show up, so now what do i do? i found it on dvdshrink and i just want to rip that one file which is only 5 megs....please help
Glad to see you found what you wanted using DVDSHRINK.
To rip the file you want you need to select to reauthor the DVD.
Once you have selected to reauthor you will have three windows, the DVD will open in the window on the right.
Find the part you want by previewing and then once you have found it drag it to the top window on the left.
Then select the backup icon and you will see a dialog box open up.
Here you can specify how to back it up.
Choose the 'folder' option and specify a location to store it then select 'OK' (i think) it will then rip this one section to a VOB file (VIDEO_TS FOLDER).
After a few seconds you should have what you want.
Any problems just ask again.
Sorry if this is a bit vague but its difficult to describe without having the program in front of me - I'm at work! -
true....thanks...i'll look into that soon...thanks for ur reply i'll let u know what happened
After ripping the DVD to your HD, you can use DVDx, DVD2AVI or Virtualdub MPEG2 to convert to AVI or frameserve to another encoder (if you want an MPG or DIVX).
Originally Posted by HARRYSPADGE
oh my god!!! i love you!!! it worked and i got it to rip!! thanks so much!! -
Excellent, I'm happy it worked for you.
I've only just started using this forum so I'm pleased I could help somebody so soon.
DVDFab - rip BD, including menues WITHOUT main title
By ptaylor999 in forum Blu-ray RippingReplies: 5Last Post: 9th Sep 2014, 12:37 -
Rip chapter in every language in every title
By kentmgf in forum DVD RippingReplies: 2Last Post: 23rd Sep 2011, 11:22 -
Separate multiple title DVD into single title DVDs
By Dogpoundz in forum DVD RippingReplies: 4Last Post: 24th Aug 2011, 19:49 -
Toshiba DVR620KU Makes title named Blank Title, when I finalize a disc.
By Dim29 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jul 2010, 20:18 -
How to add a chapter or a title to ONE ONLY TITLE in a DVD?
By coxanhvn in forum Newbie / General discussionsReplies: 4Last Post: 27th May 2009, 22:16
