hi,
I have a small uncompressed avi-video from my camera with 15 fps and I want to show this video as divx on my stand-alone dvd player (PAL).
I have tried to convert this video to an divx with 25 fps using virtualdubmod (I have selected in the menu as follows: video/frame rate/frame rate conversion - convert to 25 fps). After conversion, the "file information" button shows me, that the divx-video has now 25 fps, however, the sound is not syncronized.
Any idea, how I can solve this problem?
goana
Try playing the 15 fps divx in your player. Make sure you have a problem before trying to fix it. Most divx player will play just about any framerate. Just because your player *outputs* PAL doesn't mean that you have to only give it PAL avi's.
thanks for answering,
my stand-alone dvd player (a philips DVP720SA) play the video but the sound is not synchronised with the movie after conversion to 25 fps.
when i play the video on my pc, there is no problem.
goana -
I'm saying don't convert it to 25 fps. Why are you converting it, and making audio synch problems for yourself?
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 23:42 -
MP4 29.97 fps to AVI 25 Fps
By videopetur in forum Video ConversionReplies: 4Last Post: 20th Jan 2009, 07:37 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 16:23 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 20:17 -
30 fps flv to 25 fps avi or vcd
By cd090580 in forum Video ConversionReplies: 5Last Post: 12th Nov 2007, 09:35
