a friend of mine purchase recently a JVC GR-D73. help him connecting his camcorder to his pc, but whenever we install the driver an error mssg comes out, windows logo did not passed (something like that). i tried everything but no luck. pls. help!!!!
Results 1 to 11 of 11
tried click Continue anyway ? or is it no such button?
tried that also, clicking "continue anyway", it always comes back. so still my pc doesn't detect the camcorder
i even tried these drivers given by this site http://www.jvc.co.th/service/download_driver_vdo.htm still doesn't help any
Why are you trying to use USB? USB on DV camcorders is usually only for low resolution video and still shots. You should be using firewire (IEEE 1394).
his pc has no firewire card, that's why he wants to use and practice capturing/transferring using USB.
It sounds like the error message you see is simply Windows warning you that the driver you are installing wasn't tested and certified by Microsoft. This is quite common when installing drivers. If you select "Continue anyway" the driver will install.
When you say your computer doesn't see the camcorder, what do you mean? Plug the camera in and turn it on. If you go to the Control Panel and look under "Scanners and Cameras" is the camcorder listed? Or do you mean your capture application doesn't show the camcorder? What application are you using? -
i already tried "continue anyway" but it still keeps coming after it installed the driver. still the pc can't detect camcorder coz the driver is not working, (this what i mean "pc doesn't see the camcorder").any application i use doesn't detect any camcorder (its on) plug on my pc, windows movie maker, imager...
Your friend will have to get a firewire card, preferrably one with a Texas Instruments chipset, to transfer the video. They are not that expensive. JVC's seem to have a problem when you use other firewire cards with different brands of chipsets in them. Have a look over at www.camcorderinfo.com to see why to use TI chipset cards. In the forum there is a slew of people with problems with firewire cards. USB is used only to transfer the still pictures that it takes. Firewire is the way to go for digital video transfer.
Good luck,
Ethan -
Actually, that is supposed to happen. I too thought that I was doing something wrong, but there are in fact 4 drivers that need to be installed in order for the camcorder to work properly. One is located under "Imaging Devices", the other is located under "Sound, video, and Game Controllers", and the other two under the "USB controllers". When installing the camera, it's as if you're installing the same driver 4 times, but rest assured, they are 4 different drivers. And you would have known that if you read the instructions =D
Just make sure you hit the "Continue Anyway" 4 times, once for each driver, and you'll get the "Device is installed and ready to Use" confirmation.
....Anyhow, I'm having a problem with this camera. I can't use it as a webcam on Yahoo, AIM, or MSN Messenger. The camera itself is not listed under the "Cameras and Imaging Devices", although it is listed under Device Manager's "Imaging Devices". I am, however, able to at least set it up in Windows Movie Maker, though when I try to start a capture I get the error message "This device is currently being used. Please close all other applications using this device and try again." The only problem is, the camera is NOT being used by any other program. Unless the USB capability is keeping me from using the camera... in any case, I'm PO'd because the manual says the camera can be used as a webcam, but fails to instruct you how to do it properly. I tried restarting the computer (like, 9 times), and removing drivers, reinstalling them step-by-step, just to be safe, and nothing.
Can anyone help?? (-- JVC GR-D73; Windows XP Home Edition, SP2; 1GB Ram, 80GB Hard Disk; NVIDIA GeForce 6200SE TurboCache; --) -
Thank you Chris! I only had one more installing to go for the success, without knowing it. All tought I didnt come across any instructions that you mentioned?Originally Posted by ChrisRodrigues
Have to say Im totally happy about the camera, only thing bothering tiny bit is the microfone located inside the camera, capturing the noise from the video, but still exellent buy for 300$,brand new.
Thanks again.
External HDD with USB 3.0 - problems connecting
By alintatoc in forum ComputerReplies: 10Last Post: 14th Apr 2012, 14:04 -
Connecting USB harddrive to Philips DVP-5990/37 player
By DVantrease in forum DVD & Blu-ray PlayersReplies: 12Last Post: 12th Aug 2009, 20:30 -
Problem Connecting PC to TV via HDMI
By M.AD in forum Media Center PC / MediaCentersReplies: 1Last Post: 23rd Feb 2008, 17:05 -
JVC GR-D73 "Currently in Use" error
By ChrisRodrigues in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 7th Feb 2008, 20:31 -
Problem connecting PC and LCD tv
By rozenokolis in forum DVB / IPTVReplies: 1Last Post: 26th Jul 2007, 17:37
