i was at an out of town wal-mart today and saw the pioneer dvr-231s, it looked similar to the pioneer dvr-220s that i have.. and was priced the same ($198).. has anyone used this dvd recorder? has pioneer finally fixed the bugs from the 220s and packaged it as the 231s?
i almost want to buy it and and out.
i posted my review of it in the dvd players comments;
https://www.videohelp.com/dvdplayers.php?DVDnameid=4512&Search=Search&#comments
Results 1 to 11 of 11
Yes, what bugs in the 220? My guess is the 231 is the Walmart-only version of the DVR-233S. All I know about the 233 is that it has a maximum 10-hour recording mode and only one set of inputs on the back. A couple non-familiar online retailers claim to have the 233 in stock but yours is the first sighting I've heard about of a new model.
My brother just bought a 320S because he wanted the Firewire input and didn't want the hard drive models. Pioneer apparently will only have Firewire in the hard drive models in the future, so the 320S is the last of its line. -
Yes. Do elaborate on the bugs in the 220-S version, because I'm
unaware of them. All I do know, so far, for my dvd recorder projects,
I've never come across any. (sure, someone posted a "black-out" issue
with vhs tapes, but I haven't been able to duplicate it. Thus, I have
ruled that issue out as a false bug.
And, that is *THE ONLY* bug that seems to be going around here, for
the 220-S unit.., hardly worth throwing you's out the window
..one bug ?
Anyways
Cheers,
-vhelp 3327 -
Originally Posted by vhelp
The 220-S has received complaints about excessive grain on the recorded image. Could this be what lumis is talking about? -
maybe i went a little rough in calling them bugs.. but
1) support recording from 16:9 & maintaing the correct A/R (without having to patch on the PC)
2) support recording at 192kbps ac3 (256kbps is just a waste, and so is LPCM). (not really a bug)
3) multi-system (NTSC/PAL) dvd video playback support (not really a bug, but c'mon)
4) support DVD+R DL for playback, i can understand not recording them.. you should especially when the book type is DVD-ROM. (totally a bug)
the 320 is exactly the same machine as the 220, with the exception of the firewire/dvi port, correct?Originally Posted by Frobozz
the 231s i saw didnt have a firewire port on it.. thats what made me think it was a newer version of the 220.
Here's the Pioneer web page on the 233. One Call and J&R have them in stock for $199.
http://www.pioneerelectronics.com/pna/product/detail/0,,2076_15020669_236514640,00.html
Here's a decent picture of the 233 from a Japanese web site...
http://www.watch.impress.co.jp/av/docs/20050107/ces04_03.jpg -
Originally Posted by lumis
1. I've recorded 16:9 shows all the time. No problems.
2. I'll have to check that manual again. I thought the 220-s had 192kbps ac3?
3. Multiregion? Absolutely! They're should be a hack.
4. I've played a friend's +R discs on mine. (Taiyo Yuden)
The only bug I can see is the excessive video noise, on TV recordings. Even if the cable/sat signal looks decent on you're monitor, theirs just too much of it. But a good signal booster from Radio shack should solve most of that. The 510H seems to have this problem as well. On direct TV to DVD-R recordings. -
robert black,
a friend of mine and i both have this dvd recorder. so i'm sure this is not just an isolated incident.
1) if i were to record from a true hdtv source in dvd-video mode, finalize the disc & give it to a friend who had a regular dvd player and regular tv, everything would be all out of proportion. the player records in 4:3 only, although you can force 16:9 with your tv.
2) it has LPCM & 256kbps ac3..
3) ...
4) i said DVD+R DL, double layer DVD+R discs. it will not play them. and it pisses me off. probably because its using a DVR-104 drive that doesnt check the booktype like most drives do.
gshelley,
yep, thats the player.. it doesnt seem like its as good as the 220.. it only has 2 inputs, 1/front & 1/back.. nice find on the website, i couldnt find it for crap.
lumis,thanks for clearing all that up. Yeah, I've never played +R DL discs on the 220-S, only the single layer. As for capping a true ATSC HD source, quite frankly I'm surprised it capped any image at all. My understanding is that most of these recorders can only handle NTSC standard period.(PAL in euro models or hackable recorders) But good to know you can get some sort of image(although AR messed up) from an HD source.
Pioneer DVR-550H-s: transferring video from laptop to DVR's Hard drive
By anandmahey in forum DVD & Blu-ray RecordersReplies: 3Last Post: 30th Aug 2012, 06:38 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 20:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
Pioneer 231s just died, advice needed on new recorder
By heman28 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 7th Feb 2008, 20:58 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02
