Is there a way to rip a scene from an mpg or mpeg? I ripped a dvd to mpg form and not I want to rip a certain scene from that mpg. Not to mention I have other mpg's with scenes i'd like to rip. Is there any type of program or way of doing this? Also I'm trying to rip a scene from a VCD. Is that possible? How?
TMPGenc. Use MPEG Tools-> Cut and Join. Select the portion you want and you can then export it (be sure to export it as the same format!). If you want to encode to a different format such as MPEG1 or DivX avi, just do a source range before encoding. For DVD export as MPEG-2. For VCD export as MPEG-1 VideoCD. Hope this helps!
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
Ripping Music Videos From WTV - DVR-MS - MPEG?
By skywalka in forum EditingReplies: 5Last Post: 12th Jan 2011, 02:13 -
If i ripping a DVD Movie to H264/MPEG-4.
By skorpinok in forum DVD RippingReplies: 4Last Post: 24th Aug 2010, 11:12 -
Ripping straight to mpeg
By NurEinTier in forum DVD RippingReplies: 7Last Post: 22nd Nov 2009, 09:11 -
ripping a avi/mpeg back onto computer
By pw29010 in forum DVD RippingReplies: 2Last Post: 16th Feb 2009, 16:34
