hello everyone, i just wanted to ask if anyone can assist me in constructing a well organized PDF, nothing fancy just, making book marks, pages and stuff. the main focus is that i have JPG scans of book pages and i want to compile them onto a PDF. please post generously...thanks.
Results 1 to 17 of 17
Wow! You got shocks, pegs... LUCKY!
I'm assuming you have a full version of Acrobat Pro 6.0 or later?
FB-DIMM are the real cause of global warming -
Hopefully it's the same for 7.0, I'm still using 6.
Get all the images you want to make the PDF out of in one place. Go to File > Create PDF > From multiple files... and browse to the folder where you've got the files. Select them all and then rearrange them. May be easier to do this by chapters first and make seperate PDFs for each chapter and then assemble the chapters.
If you import everything at once scroll to the beginning of a chapter and the bring up the "Bookmarks" window by selecting its tab on the left side of the Acrobat window. Use the "Create Bookmark" button at the top of that new window to set a chapter bookmark, name it what you want. There are some other options available for bookmarks under that tab if you want to play with it.FB-DIMM are the real cause of global warming -
hey thanks that sound simple enough, ill post when i get some results...
Wow! You got shocks, pegs... LUCKY! -
that was probably the easiest thing i've ever performed, thanks man...
No problem. Acrobat is at least one application I'm very familiar with, gotta use it everyday at work
NICE! well thanks for the help, and keep up the good WORK.
ok now another task, how can i make a PDF as a web page?
I don't follow. PDF is a document format, a web page is a script. You can link to the PDF from another web page but it will then still be a PDF and must either be downloaded and viewed locally or viewed through the browser via the Acrobat plugin.
o ok then that is what i mean, sorry please understand im not that experienced when it comes to acrobat. so could u please advise on how to create a PDF so that it is downloaded or viewed with the browser...thanks.
You just upload it to your website and link to it like any other downloadable file. It is then up to the person viewing it how they'd like to handle it, be it downloading and viewing or viewing though their browser.
ok so i actually need a website to put a PDF online, i can just use some random page somwhere...ok well, thats fine.
Just store it on the web somewhere. There are tons of free sites out there if you don't have a website yet. Then, all you do is direct people to go to
Usually, Acrobat Reader opens up in their internet browser. Either that, or they will do a "save as" and open it up on their own.Code:http://www.yoursite.com/file.pdf
o thanks, btw, i like ur avatar ... :P
just as a sidenote, OpenOffice is a Free MS Office Alternative and it will natively convert any office document to .pdf.
I know you may be thinking Free = poor quality, but you will be very surprised if you try it out. For the general office user it does everything you could want and more. It is java based so the initial load up time is a little longer than MS Office..but it's FREE and it can read/write files in office format. -
sounds worthy, ill try ANYTHING if its free, not that im stingy, of course... :P
Is there a PDF for ffmepgX ?
By midiw in forum ffmpegX general discussionReplies: 3Last Post: 20th Jan 2011, 10:23 -
Best PDF Editor..
By Soccerman77 in forum ComputerReplies: 1Last Post: 4th Nov 2010, 20:50 -
eBooks to .pdf?
By rotuts in forum MacReplies: 8Last Post: 23rd Oct 2010, 03:59 -
PDF file help
By jyeh74 in forum ComputerReplies: 14Last Post: 11th Jun 2009, 00:45 -
jpeg to PDF is OK! But PDF to jpeg?
By bryankendall in forum ComputerReplies: 2Last Post: 14th Sep 2008, 16:53
