I used Sonic MyDVD 6.1 to transcode and create a DVD folder (to test the DVD without wasting a disk). I then burned the folder's contents to a DVD using Easy CD Creator 5 to a Fujisoft 8x DVD-R in my Sony DRU500A. I burned it such that the 3 directories: JACKET_P, OPENDVD and VIDEO_TS were in the root directory of the DVD-R. Windows Media Player recognized this disk as a video DVD when placed in both the DRU500A and an old Pioneer DVD drive.
I then tried to play the DVD-R in my PS2 which can recognize other DVD-Rs and it didn't recognize the disk as valid. I tried the disk in another player, Sylvania SRD3900, which can read DVD-Rs and it could not read the disk either.
I compared the disk to another than can be read by my PS2 and the only difference I can see is that some files that are hidden on the disk that can be read are not hidden on the disk that can't be read. Specifically the 3 files in the JACKET_P directory and the SOURCES subdirectory in the the OPENDVD directory. Could this be causing the problem?
If not any idea why DVD players are having problems with this disk?
Well I figured out that it is important that those files remain hidden since I tested a DVD+RW without them being hidden and it did not work. Easy CD Creator does not keep them hidden.
Sonic RecordIt Now, that comes with MyDVD 6.1, does and it successfully burned a DVD+RW that worked.
Unfortunately trying to burn a DVD-R with Sonic results in Sonic not responding and locking the DVD burner driver so I can't even shut down Windows. I need to hit the reset button. -
Create the various DVD folders on your HD, Use ImgTools classic to create an iso image, then burn with DVDdecrypter
There are 10 kinds of people in this world. Those that understand binary...
Burned Video DVD Won't Play in Standalone Players
By adamwolf1965 in forum Newbie / General discussionsReplies: 2Last Post: 1st Jun 2009, 22:21 -
Burned DVD only plays in newer players
By rsherid in forum Authoring (DVD)Replies: 11Last Post: 16th Jan 2009, 05:02 -
DVD Players no longer work on tv?? Any ideas?
By -mm- in forum DVD & Blu-ray PlayersReplies: 4Last Post: 15th Nov 2008, 20:13 -
Disc will/wont work between different DVD players.
By Scroogle in forum DVD & Blu-ray PlayersReplies: 3Last Post: 17th Jan 2008, 15:41 -
a 700 mb movie burned in 1 cd would it play on DVD players
By ianskiee in forum Newbie / General discussionsReplies: 5Last Post: 10th Jul 2007, 13:05
