This is my very first post -
I have been happily generating dvds with simple menus for about
6 months using a DVDAuthorGUI and MPEG Video Wizard with
a lot help from the internet and this site in particular (thanks!).
I am also learning more about the "parts" spumux and dvdauthor
and have actively played with dvdauthor xml. Now, I am interested
delving into some of the odd details that have been noticed.
I have a Pioneer DV-578A DVD player and have noticed that
my created DVDs that the menu item never start highlighted.
Once I push an arrow button a menu item is highlighted. This
problem does not occur on other DVD players I have tried including
2 different Toshibas. I remember reading somewhere that
there is a bug with the Pioneer players; but I have been unable
to locate the reference. Does anyone know what the problem is
and is there a way of forcing the DVD to highlight properly?
You can try to set the "default" highlighted button explicitly in your author.xml file.
Example:Code:<menus> <video format="pal"></video> <pgc> <pre> { button = 1024; } </pre> <vob file="e:\Temp\MMMenu.mpg" pause="inf"/> <button name="MMB1">g1=1;jump title 1;</button> ...
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Thanks Borax!
It partially worked - with "{button = 1024;}" the first menu item is selected but still not highlighted. So I still can't see that a the button selected, but before not only not highlighted but it wasn't selected until I hit an arrow ... its a definite improvement. I will have to run a few more test cases.
The 'name="MMB1"' is not compatible with DVDAuthorGUI. I get the following error "ERR: Cannot find button '1' as referenced by the subtitle." I am assuming that that it has to do with how the button has been setup with spumux and DVDAuthorGUI sets things up differently with different references. -
The 'name="MMB1"' is not compatible with DVDAuthorGUI...GUI for dvdauthor:
DVDAuthorGUI does not label the buttons. Just keep them blank (without a label). To do what borax suggests, just insert the following text before the 'VOB' tag in the menu.
Code:<pre> { button = 1024; } </pre>
According to another user in a german forum (molevcd) this problem can be solved by using "still menus" with ~ 1 second length (25 frames in PAL)
GUI for dvdauthor:
Thanks Borax -
I finally noticed your final response and changed the still menu framecount
to 30 (for NTSC) and it works wonderfully. Did not even need any of
the other highlighting changes.
Odd Recording Volume Problem
By blewyn in forum AudioReplies: 5Last Post: 10th Feb 2013, 12:27 -
Odd Audio Sync Problem
By Startropic1 in forum Video ConversionReplies: 0Last Post: 13th Aug 2010, 00:07 -
Need help with odd problem with erasing/recording DVD+RW
By fdm2000 in forum ComputerReplies: 17Last Post: 3rd Nov 2008, 18:02 -
Help with odd problem recording/erasing DVD+RWs
By fdm2000 in forum Newbie / General discussionsReplies: 1Last Post: 30th Oct 2008, 08:24 -
Menu Buttons looking odd
By TerryNG in forum Authoring (DVD)Replies: 1Last Post: 21st Jun 2007, 00:28
