Hi i've downloaded a movie, 2 cd's in all, both in bin/cue format. I had to change the cue files a little to point to the correct dir for the bin file and also one of the cue's had all the info on the same line(which made nero pop up an error). The second cd works fine and is recognised as a VCD 2.0 by my DVD player(Samsung 709). The 1st cd however is recognised as a VCD 1.1 and plays without sound and extremely jerky.
I have a feeling it's something to do with the cue file being incorrect.
This is cd1 cue file:
FILE "G:\XXXX.BIN" BINARY
TRACK 01 MODE2/2352
INDEX 01 00:00:00
TRACK 02 MODE2/2352
INDEX 01 00:13:20
TRACK 03 MODE2/2352
INDEX 01 37:52:08
And this is cd2 cue file:
TRACK 01 MODE2/2352
INDEX 01 00:00:00
TRACK 02 MODE2/2352
INDEX 01 00:16:02
If there is no obvious error with cd1 cue file is there any program that will create a cue file from my bin file? I've had a go with cdmage but don't think it's possible.
Thanks in advance for any help!
FraS..
ISOBuster or other program that allows you to extract the files from the BIN might help. Your CUE file looks fine, like you said, but the BIN file may have problems. With http://users.pandora.be/smart.projects/isobuster.htm you can pull the video files out and see if they play OK on the PC. It's a place to start...JimJohnD
Invalid file format
By DeepthiFdo in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jun 2011, 07:33 -
How can I salvage ISO with invalid UDF File Syetem?
By V Bot in forum Video ConversionReplies: 1Last Post: 10th Jan 2010, 20:37 -
TMPGEnc Freeware says 'invalid file'
By Leo48 in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2009, 05:42 -
VideoStudio 9 / DVD Shrink error: invalid data contained in file
By JediPM in forum Newbie / General discussionsReplies: 1Last Post: 20th Jan 2008, 16:20 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 08:40
