  1. How would you go about converting Ogm files
    USA
    Video or Audio? The video is usually XVID or similar. I usually save out the OGG audio, using VirtualDub Mod, as a WAV, then convert or use that in a MPEG encoder. The video, if XVID, process like any other XVID.
    If you look in 'Tools' there is a OGM and OGG codec you will probably need. Along with a XVID codec if you don't have one. VLC Media Player can usually play them without any external codecs installed.
    BTW, covert to what? A little more information would be useful.
  3. Sorry about that lack of info. I want to Convert Ogm files to dvd files or at least mpeg 2 . I also want to add the subtitles in. I'll have to check out the programs you said earlier. I am able to play the ogm files so i have everything i need play te video
  5. Banned
    May 2003
    Massachusetts
    Pick an encoder. Any encoder. Mainconcept, TMPGEnc, avi2dvd, you name it.
  6. Will avi2DVD get the subtiles from the ogm files, if not what can i do to get the subtiles from them ogm???
    Dec 2004
    Australia
    Anything that takes input via dshow should encode with subs if it playsback with subs. Although TMPGEnc has some issues with directvobsub.
