I have a couple of AVI files burned onto CD-R's that I want to convert to VCD, or DVD files. I need them to be able to work on a standard DVD Player and I do not know what file format I need to convert them into for them to be abe to work. I asked someone at the Apple store if iMovie would do this. And they said yes. However, I need to know step by step instructions on how to convert video files using iMovie. These video files that I have are in Japanese with English subtitles. And I have a Mac OS 9.2, but soon to be upgraded to 10.4. Anyway, if any of you know about iMovie, please help
love, luck, and lollipops ^____^
Hi puchiko_chan,
Welcome to the forums.
What you want to do is certainly possible. I'm a PC user, so not sure of what applications there are for Macs, but a good place to start is over in the "How To" section to the left. There's all sorts of guides etc.
Also, it might be worth checking out the specs for VCD, SVCD and DVD so you know what you're dealing with and may be able to avoid potential problems.
From personal experience, I found starting with VCDs then SVCDs a good basis before moving on to DVDs - DVDs are / can be more complicated, depending on software, approach etc.
Definitely get a re-writeable CD and DVD - no coasters!
Enjoy, and good luck!There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
puchiko_chan, while iMovie MAY work, the best bet is to use ffmpeg x or mpeg2works. There is a tutorial done by Galactica http://webpages.charter.net/ernsta/DIVX2DVD.htm that explains how to convert a DivX avi to DVD. Divx is one of the most popular forms of avi around and will probably apply to your files, Assuming you want to keep your subtitles, then go with ffmpeg x. There is a forum on this site that the software author frequents and he can help you with specific questions. There are tutorials on his site http://homepage.mac.com/major4/ that deal specifically with your issue. Look at the "How-tos" section.[/i]
puchiko_chan
Some of my guides are out of date, let me know if you have any problems.
Hopefully i can get them updated soon!
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
