Hi,
My Sony DW-D22a says it supports 'EP mode' to get up to 4 hrs. Anyone know how can I make use of this?
Also I am wondering if dual-layer DVD's will work in all players like commercially-made ones.
No, DVD-DL discs are not compatible with all players. They suffer from the same issues as -R and +R discs...only worse.
You can get more video onto a DVD by using any number of the apps listed here to re-encode your files at a lower bit rate.Google is your Friend
Best IDE Burner for burning Dual Layer or Single Layer Discs for Duplicator
By Konfusion in forum DVD & Blu-ray WritersReplies: 7Last Post: 18th Nov 2011, 04:16 -
duel layer to single layer question
By joelw_7 in forum DVD & Blu-ray WritersReplies: 7Last Post: 1st Jan 2008, 02:25 -
Single Layer / Duel Layer?
By Bathouse in forum Newbie / General discussionsReplies: 3Last Post: 4th Dec 2007, 10:16 -
20 Hours on a single DVD?
By Alienverse in forum Authoring (DVD)Replies: 45Last Post: 26th Oct 2007, 14:11 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 14:39
