  1. I enabled the "Decode with Quicktime" option in ffmpegX to encode directly from the .mov file of iMovie to an xvid file with the ffmpeg xvid profile, but while I've non problem with the video stream which is encoded correctly I can't encode the audio stream because ffmpegXprogress states that "the audio codec is not supported": there is a workaround?
  2. Try to flip "Normalize" in the audio tab.
  3. I'll try a.s.a.p.
    thank you for your fast reply.
  4. Sorry major but with the ffmpeg xvid profile selected the "normalize" box in the audio tab is dimmed and unchecked by default.
  5. Sorry. You may try to use Quicktime Player to export the sound to WAV and mux it back to the video-only AVI.
