Can anyone recommend a specific tool for normalizing mp2 audio files, without reencoding? Thanks in advance.
Paco
Results 1 to 13 of 13
Cant be done without re-encoding.
I've read there are tools able to normalize without reencoding mp3 files. I hope to find some program to do the same for mp2 files
Where did you read that?Originally Posted by Paco M.
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
I think this misperception arises from programs like MusicMatch Jukebox which has a normalization feature which doesn't alter the mp3 file. It simply builds a database of volume levels for each file in its playlist and uses it at playback time to normalize the volume. But of course, only MMJB understands and uses the database.Originally Posted by Paco M.
To actually make volume level changes within the file requires reencoding. -
Look at http://www.dansmc.com/freestuff/nobucks/mp3.htm for MP3Gain.
At least in theory, this program does for MP3 files what I want to do for mp2 ones. -
Thanks for the link. I had not seen that before.
I tried a few Windows based software players and they all supported the feature. I tried my DVD player (which can play mp3 files) and it worked there too. I'll have to try the player in my car later...Originally Posted by Paco M.
A close examination of the files shows that MP3Gain adds a metadata field at the end of the file. I originally thought this was simply an instruction to adjust the gain on playback. But it's just information that can be used to undo the changes. It also changes a few bytes here and there within the file. So maybe each packet within the MP3 file has a gain setting?
I tried the obvious -- renaming an MP2 file to MP3 but MP3Gain wouldn't accept it. Even with the "no check for L1 and L2" option set. -
The structure of the MP2 file (which is not much different to the structure of an MP3) should allow for modifying the average volume and normalizing it. It is just a matter of scaling the encoded stream.
I think I have read something similar in articles and papers on "compressed domain transcoding" but cannot recall the exact site or find the papers now. Having a tool to do that is of course a different matter.
should be an interesting programming effort, though.The more I learn, the more I come to realize how little it is I know. -
http://besweet.notrace.dk/BeSplitv0.9b6.zip
Here's the quick way to normalize the file losslessly (per doom9 faq)
BeSplit -core( -input infile.mp2 -output outfile.mp2 -type mp2 ) -ota( -G max )
Use the Beta version above. Earlier versions don't include this function. -
After a little reading it looks like MP3Gain manipulates the Global Gain Factor within the MP3 frames. From the horse's mouth:
http://www.iis.fraunhofer.de/amm/techinf/layer3/
AC3 Dialogue Normalization so it doesn't change volume of edited original
By c627627 in forum AudioReplies: 13Last Post: 8th Jun 2011, 23:20 -
joining + trimming + subtitle creation + volume normalization All-In-One?
By sincostan45 in forum EditingReplies: 2Last Post: 30th Mar 2010, 23:53 -
mkv video audio normalization / post-processing audio normalization
By o6uoq in forum Newbie / General discussionsReplies: 6Last Post: 5th Aug 2009, 01:17 -
TDA3 Volume Normalization vs Uniformization - any experience?
By lj01 in forum Newbie / General discussionsReplies: 0Last Post: 11th Jul 2008, 12:53 -
Normalization of the sound portions of flv files
By art landy in forum Newbie / General discussionsReplies: 3Last Post: 28th Jun 2007, 21:54
