Ive been using the SVCD2DVD to try and put two svcds to dvd format. So far i have been unsuccessful. Most of the movies will play for about 2minutes, then after that, it would cut off, a few will play a quarter or half of a way through and then cut off. What can i do different or what do i need to try? Is it the program i am burning with? Or could it be something else?
Try posting in the svcd2dvd forum...
Hint its right at the bottom..
You need to supply a bit more info on what type of files you are using, how many, which version of svcd2dvd you are using and burning program used. Plus of course how you are doing it...Not bothered by small problems...
Spend a night alone with a mosquito
