    Jan 2002
    kilmarnock scotland
    Can anybody help?
    Tried to burn a dvd last night using dvdshrink. During the burning process it came up with the error message "semaphore signal timeout expired"
  2. I got this same error with DVDDecryptor using some TDK Printables from COSTCO.
    I'm using an external I/O Magic 16x burner.
    I kept thinking of Homer saying it like "Semamaphoreee" like he did with Lisa's Saxaphone, so I wasn't to upset about the coasters.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Were you using DVD Decrypter, Nero, or CopyToDVD to burn ?
    Internal or external burner ?
    If internal, is it set to DMA or PIO ?
    Has this happened before ?
    Read my blog here.
    Jan 2002
    kilmarnock scotland
    I was using dvddecrypter + nero6 with external plextor 716. Don't know if m/c set to dma or pio. Yes it has happened once when I was burning a dvd on my son's m/c ( same set-up except for lite-on burner ) but i have burned successfully on all other occasions
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    The common thread so far is both of you have experienced this problem when using external burners.
    Try limiting the burn speed to 2x and try again.
    Read my blog here.
  6. Check the DVD Decrypter forums as there is a thread dedicated to semaphore signal timeouts. It's pretty much due to the enclosure's chipset design. Some chipsets are more prone to theses errors than other chipsets.
    Thanks,
    jawgee
  7. Originally Posted by realtrain
    Can anybody help?
    I had this very same problem while using my Pioneer 109 externally by USB 2. I switched to Firewire and it has not re-occured. That message means that you are losing contact between the drive and the computer.Hope this helps.
