can anyone tell me why when i converted mysvcd the picture is more horizontal than fitting perfectly on my screen wher is the setting at and what should it be set at..........
Encode 480 x 480
4:3 aspect ratio
Make sure that you've got the source aspect ratio set to either 1:1 VGA or whatever the correct aspect ratio is.
Hope this helps... -
ya that worked thanks alot finally getting the hang of these setings............
TMPGEnc Maximum File Size for Authoring?
By cym in forum Authoring (DVD)Replies: 3Last Post: 26th May 2010, 01:55 -
picture size difference after transcoding (TMPGenc 2.5)
By jakewoodblues in forum Video ConversionReplies: 12Last Post: 27th Apr 2010, 20:57 -
TMPGenc DVD Author 3 Maximum Size
By Shadowofthedarkgod in forum Authoring (DVD)Replies: 5Last Post: 6th Apr 2008, 18:59 -
File Size Limit With TMPGEnc Plus 2.5 or MPEG-2?
By RABinMS in forum Video ConversionReplies: 5Last Post: 10th Feb 2008, 14:30 -
File size problem with TMPGEnc [.avi to .mpg conversion]
By Timex in forum Video ConversionReplies: 7Last Post: 26th Jun 2007, 21:50
