hey all.
ive started to have troubles with my burnt backups, when i play them i get stutters and pauses which i never had before until now. i have a year old PC and Pioneer a07 burner. everything in my pc is pretty much top of the line at that time. ive been ripping with dvd decrypter and using cloneDVD 2 ever since i got my PC a year ago. every backup has been perfect, until now. i use my xbox or ps2 to play dvds which always played flawlessly. i thought it was the ritek g05 which i just started to use but i re burnt it using my old prodisc media and still had minor pauses. the old prodisc i have always played perfectly on both xbox and ps2. ive burnt so many times, i also re watched all the backups and still stutters and pauses.
im just wondering if its my pioneer a07. its just a year old and wondering if the burner is the problem. is it time to get a new one? u mite say its media but the old prodisc i have alwasy played perfect but now stutters and pauses just like the go5.
thanks
Hello there!
I would first recommend trying good quality media, such as Taiyo Yuden, to be sure that it isn't the media. Check out www.nomorecoasters.com for good quality media.
From personal experience I can say that it may be the burner. I had a Pioneer 105 for about a year and after moderate use it gave up and bought the farm. It worked fanatastic until that fateful night when I got endless 'power calibration errors'. After that it never worked again.
Hopefully it's just the media in your case.
If you haven't tried a firmware update, that may help also. Check www.rpc1.com for firmware updates.
Good luck!
<W>
I have an annoying problem with my dvd burner.
By roomgrey in forum DVD & Blu-ray WritersReplies: 6Last Post: 19th Oct 2010, 14:43 -
USB External Burner Problem- help?
By Super Warrior in forum ComputerReplies: 1Last Post: 3rd Jun 2009, 23:50 -
rca dvr dvd burner problem
By ziggy919 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 1st May 2009, 20:38 -
Benq EW162I DL burner Problem
By wanghiking in forum Authoring (DVD)Replies: 9Last Post: 20th Nov 2008, 20:09 -
Problem with HP DVD300e burner
By shinyranker in forum Authoring (DVD)Replies: 4Last Post: 22nd Jun 2007, 08:18
