I try to make all of my vcd to DVD. When I use VCDGear to extract from dat to mpeg into my computer. There some corrupted segments/glitches at the end of the movie. The begining is fine but the end is so mess off that when i try to author to dvd it missing the end or stop at the corrupted segment part of the movie when I test the output movie.how do i fix this.
ya i did click on Fix MPEG Error. I even try second time from MPEG---?MPEG, still no luck
How does MKV segment linking work?
By coolxal in forum Newbie / General discussionsReplies: 7Last Post: 5th Nov 2011, 20:52 -
[SOLVED] [H.264+AAC] How to extract segment?
By yetanotherlogin in forum EditingReplies: 2Last Post: 26th Oct 2011, 08:23 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 16:26 -
Broken or not broken hard drive?
By romanstopme in forum ComputerReplies: 3Last Post: 17th Sep 2009, 12:04 -
Help:VDUB:CANNOT APPEND SEGMENT segment has a different number of streams
By lil_Dee in forum EditingReplies: 9Last Post: 23rd Jun 2009, 08:16
