I have an MPG that was downloaded and seems to be messed up. The MPG is 8 minutes long, and plays fine in Power DVD, but all other apps see it as 16 seconds long.
I've tried opeing it in Vdub, opening it with Vdub using an Avisynth script, and also tried loading it into TMPGEnc by frameserving and actually opening the file directly.
Using these methods, I can seek through the video, and see the entire thing right to the end (although seeking is slow as hell), but still these programs insist that it is 16 secs long and will always spit out a file that is 16 secs.
I tried running this through the TMPGEnc "edit/merge" feature to see if that would correct the problem, and it actually gave me 45 secs, but that's the best it could do. I also tried RADtools, but no luck.
Any ideas on how to fix this, please let me know. It's probably a header issue or something, but it's proving to be a somewhat tough nut.
Thanks!
I believe this will correct your problem.
https://www.videohelp.com/guides.php?guideid=184&howtoselect=5;22#184Google is your Friend
mkv won't play to end in Windows, but plays fine in OS X ??
By Sportyyyy in forum Software PlayingReplies: 5Last Post: 15th Apr 2011, 08:32 -
low end quadro is 5 times faster than high end gaming card
By deadrats in forum ComputerReplies: 4Last Post: 7th Apr 2011, 15:42 -
WMP11 plays .wmv, .avi, .3gp no problem but won't play .mpg?
By billman in forum Software PlayingReplies: 8Last Post: 8th Feb 2010, 17:19 -
Adding audio to end scene of mpg video
By martin01p in forum EditingReplies: 5Last Post: 10th Oct 2008, 06:04 -
WMV file has 'extra text' at end of it & PS3 won't play...
By fatguy in forum Newbie / General discussionsReplies: 0Last Post: 14th Sep 2008, 11:40
