HI, At the moment I have a panasonic digi camcorder with DV OUT only. I HAVE A LOT OF VHS FILMS I WOULD LIKE TO EDIT ON MY COMPUTER. I CANT REALLY AFFORD ANOTHER CAMERA WITH DV IN/OUT, SO HOW CAN I CAPTURE MY VHS VIDEOS'S TO MY PC WHICH HAS PINNACLE 9 INSTALLED SO I CAN EDIT THEM AND BURN THEM ONTO A DVD
CHEER MR TWONK UK
Results 1 to 10 of 10
You will need a video capture card. Look to the left under Capture Cards to see a large list. You can get an older ATI AIW card for around 50.00 US.
If you have a firewire connection on your computer, just conect. Then use Pinnacle to capture the footage.
Dont think you need a capture card. Pinnacle 9 has DV capture ability (at least pretty sure). May even be able to capture directly to mpeg2/DVD format. -
DVWannaB- I think he wants to go from VHS to his PC. According to him his camcorder doesn't have the needed inputs to do this. So he will need a capture card of some form. Mr twonk, please correct me if I'm wrong.
Here's the first card I used. On Ebay for 50.00.
https://www.videohelp.com/capturecards.php?CaptureCardRead=15#comments -
being a thick hesd,,,, does this mean all I have to do is connect my vhs video recoder via YELLOW WHITE AND RED cables, run tape and pinnacle will pick it up ????? I am at work so not able to look I am sure I have seen a card with the yellow white and red sockets... thanks everyoneOriginally Posted by DVWannaB
Ok, yeah, just re-read. The DV cam thing threw me off.
Well he could sell his DV cam on ebay and use that money for a new DV cam with video in and dv out. Then he could do what I suggested above
As long as you have the connections for the RCA cables(yellow,white and red cables) to the camcorder or to a capture card. You should be able to capture the tapes.
Well yes. Just connect your vhs vcr using red, white, yellow or Svideo cable if available to a video capture card/device. I would make sure to get a video card/device, that is compatible with Pinnacle 9, so you dont have to lay out more $$$s for capture software (although some cards come with capture software).Originally Posted by mr twonk
cheers I will give it a go this weekend, It would be simpler if I had a camcorder with DV IN/OUT wouldnt it. and in my case its extra ££££ I dont want to spend.. thanks againOriginally Posted by DVWannaB
yes it would. More like a red/white/yellow in and DV out be perfect.
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 10:21 -
For VHS/S VHS tapes 10 - 20 years old what aspect ratio should I use 3:4 ?
By fuzzblaster in forum Capturing and VCRReplies: 1Last Post: 10th Sep 2010, 17:27 -
VHS Copy Protection when using a Dual DVD\VHS Unit
By wizer in forum Capturing and VCRReplies: 1Last Post: 20th Sep 2009, 15:25 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 09:19
