Results 1 to 13 of 13
    Jan 2004
    MI, USA
    I am planning to buy a DVD player, what all the things i should see while buying. I am buying the DVD player in USA and going to use in Asian region. What is NTSC and PAL system ? should I have to look for these while buying a DVD player. Please guide me .
    Thanks in Advance,
    Thiyagu
    Mar 2003
    New England, USA
    NTSC and PAL are standards that define how a video signal is sent to a TV. Basically, the numbers of lines on the screen are different and so is the way the colors are coded in the signal.
    Look at this table to see which standards countries use: http://kropla.com/tv.htm.
    Most recent DVD players now can play both standards and even convert. For example, I live in the USA and the TV standard used here is NTSC. My DVD player sends the output video to the TV in NTSC of course but it can also read a PAL DVD and send a converted signal to my TV in NTSC, it does the conversion on the fly.
    Another thing to be aware of is that commercial DVD's have a code on the disc that tell the DVD player in what region of the world the DVD's are meant to be played. For example, the USA are part of region 1, Europe is part of region 2, etc... A region 1 DVD cannot be played in Europe in theory. But most DVD players especially manufactured in Asia come region free so they are able to play any DVD. There is also the possibility of entering a set of commands with the remote control of the DVD player to make it region free. Take a look in the left column of this web site at DVD Hacks.
    What you will have to check too is the difference in power voltages and frequencies. Here in the USA, the voltage on power lines is 120 Volts with a frequency of 60 Hz. In other countries it may be different. In my native country of France, for example, the voltage is 230 Volts with a frequency of 50 Hz. Take a look at this table to check your own country: http://kropla.com/electric2.htm. It is possible to buy adapters/converters if it is different in your country. Some DVD players will be able to operate on both voltages/frequencies without converters but you really have to look.
    Jan 2004
    MI, USA
    Hello Gildas
    Thankyou verymuch for your valuable information.
  4. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Consider a true dual standard model (region free) that will play both PAL and NTSC DVD plus optimize playback on either a NTSC or PAL TV. A PAL DVD playback through a NTSC player to a PAL TV (NTSC Mode) may be severely compromized.
    Jan 2004
    MI, USA
    I am planning to go for a basic DVD player and I have seen three players with the same features and prices. Which one would be better on the performance . Which one you recommend.?
    These are the three models..
    http://www.bestbuy.com/site/olspage.jsp?skuId=6100961&type=product&productCategoryId=c...=1069297420815
    http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=ELEC&pid=0575715...at=DVD+Players
    http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=ELEC&pid=0575785...at=DVD+Players
    Thiyagu
  6. i got cyberhome for $25 about 5 months ago, and it's wonderful make it region free just using remote, and plays any system.
    lokk for hack on the right at dvd hacks
    Jan 2004
    MI, USA
    Hello Lenti,
    Which model did you bought?? I have chosen the model CH-DVD300S .
    But i couldnot find the DVD hack for this particular model.
    If you could find it somewhere kindly send it to me.
  8. i have this dvd player by LG model DV7832NXC which i purchased at Futureshop here in Canada. my question is does enyone can tell me if this can convert PAL dvd to NTSC signal? i'm planning to buy european dvd and i'm wondering if this will work on my player. or is there a hack for this? thanks.
    Jan 2004
    MI, USA
    I bought the Cyber Home CH-DVD300S DVD player and I found that the movie quality was very bad. Brightness increases and decreases often. I checked with two or three DVD's still i have the same problem. What may be the problem.?
    Thiyagu
  10. What a surpirse, bad picture on a cheap player? Im shocked. Just the "brand" name alone, Cyber home, makes me wanna trust it with my life
    Edit: Means there might not be anything wrong at all, but lets hope it is.
    Aug 2003
    San Francisco, CA
    The problem with Cyberhome 300 series is that their quality isn't very consistent. I wouldn't recommend purchasing a Cyberhome without a extended warranty. To play my first DVD on it, I had to go back to the store three times. The first quit entirely. The second played audio for a half hour. This third one has been relatively trouble free for almost a year.
    I play all kinds of disks. I have studio disks from Regions 1,2,3,4,and 5 and a bunch of DVD-Rs. Only three disks have given me some problems out of about 250. So that ain't bad.
    I also have a Sungale 2026 that I bought for $30. It seems to handle factory disks better than the Cyberhome, but not the DVD-Rs my nephew burns.
    $60 is cheap enough to cover all the bases.
  12. Member AlecWest's Avatar
    Mar 2002
    Vader, WA, USA
    I have had the following $49 DVD player for a while now and it plays anything I put into it ... PAL or NTSC:
    http://yamakawadirect.com/275_detail.shtml
  13. Originally Posted by thor300
    DUDE, I got a ******* Sony 1 yr ago, and it sucks, when it switches the layers, sometimes it frezes and jumps. You wanna trust your life to sony ????
    If you're stupid enough to pay extra for nothing, go for it, I did it....and I got burned.
    Cyberhome works wonderful for me, Sony is a expensive piece of shit.
