I 'm not sure if theis is possible but when I added my pictures / images to timeline I had the length set to 5 secs in the options. I now wish to make this 8 secs. Is there any way of doing this for all images without amending them one by one. If you select more than one clip then the option is greyed out????? Also if you change the time in oiptions then it only affects pictures put in afterwards....
Results 1 to 1 of 1
Cut Out Segments Of Video Using Womble MPEG Video Wizard DVD
By luckyace in forum Newbie / General discussionsReplies: 2Last Post: 4th May 2017, 03:46 -
Womble MPEG Video Wizard DVD is re-encoding video, claiming not to (FIXED)
By Brad in forum Authoring (DVD)Replies: 11Last Post: 2nd Mar 2012, 20:28 -
Small help with Mpeg Video Wizard. Thanks.
By seymoria in forum EditingReplies: 3Last Post: 6th Sep 2008, 21:07 -
Womble MPEG Video Wizard - adding video files to dvd maker help?
By nightrider in forum Authoring (DVD)Replies: 3Last Post: 5th Mar 2008, 08:52 -
How to use Mpeg Video Wizard
By windranger in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2007, 08:24
