Upgrade question:
Have:
Nero, v. 6.3.1 (OEM version, came with DVD burner)
just bought:
Nero v. 6.6 purchased in a box at Fry's.
Do I need to uninstall before installing the upgrade?
Can't find any answers at NERO.com or in-the-box...
What's the recommended procedure for upgrading, from
Nero 6.3.x to new Nero 6.6.x?
Results 1 to 19 of 19
-- Geo :: I play ALL my * .AVI files on my Philips DVP642 !!!
Save your URLs and share URLs -- FURL your links at http://www.FURL.NET/ -
Since you are actually upgrading...uninstall the older version...then install the newer version. Also, after your installation..there is most likely an update on the Nero website.
Google is your Friend -
Hi. Thanks. When I put in my new Nero 6 install CD-ROM, it says it will do the upgrade/install... so I let it go auto...
Let it upgrade
But also go to www.nero.com and get all the latest upgrades. -
AOK. Thank you!
Now... I'm trying to decide which file extensions to allow for Nero, which for MS Media Player, and for iTunes / Quicktime... ugh!-- Geo :: I play ALL my * .AVI files on my Philips DVP642 !!!
Don't let nero have any of them.
choose later using "open with" and "chooseprogram" -
Now, that sounds TOO easy!
I wonder ... which progs are best for which extensions... I like to play all my .MP3s in iTunes... best U/I, best features, by far...
But for video, .AVI, .MPG, movies? I have an old, slooooow PC with Win2k PRO. and the DRM stuff in WMP really gets in the way!!! I hate the U/I for WinAMP, it sucks big-time!
Any recommendations for a fully powered, light-weight video player?
Still, I'm very confused about where to put CODECS and which players to use for which files...
Later!-- Geo :: I play ALL my * .AVI files on my Philips DVP642 !!!
Light Weight: Media Player Classic or
Windows MediaPlayer 2 (MS 6.4x)
Codec Aware: Zoom Player
Payware Necessary for DVD: Cyberlink PowerDVD
Intervideo WinDVD
or Sonic CinePlayer
(one of the above)
with these you play all but WMV and RM correctly
and VideoLan Player is also great to play dvd over network! -
Does Nero v6.6 come with it's own set of codecs?
Thanks, dcsos ! PowerDVD came with my DVD burner drive.
I've tried PowerDVD... and, a WinDVD demo...
WinDVD runs VERY poorly on my poor slooow 450MHz AMD Athlon! I suspect it is a CPU hog... PowerDVD seems OK, and iTunes runs real nice...
even on my Windoze PeeCee!
BTW,
Does NERO 6.6 supply its own set of CODECS?
Where to find a concise guide to Windows CODECS for novices?-- Geo :: I play ALL my * .AVI files on my Philips DVP642 !!!
NEWS -- Nero.com website + Nero 6.6 CD-ROM updates...
Sheesh, they do NOT make it easy!
I bought the Nero 6.6 Ultra package at Fry's, two weeks ago, and it looks like that CD-ROM was made a 3-4 months ago, so that's why I needed some updates....
If you click the nero logo on the Nero Smart Start, it does a little checking for updates available on the web, and versions installed, but it is VERY incomplete...
http://ww2.nero.com/enu/prog_versions.php
Lists all the version numbers. Then, you have to open each Nero tool in the whole bloody Nero tool suite, and do a right click... About... to find your version numbers. Then, check the version you have against what's listed on the webpage...
Sheesh...
Then, you have to download five or six different files (some BIG ones) of update packages, one-by-one, that takes almost half an hour with DSL, you get five files, about 100MB.
Then, you gotta install each one of your five or six big downloads separately...
This whole process takes you maybe an hour!!!
You think those smart folks at Nero AG could simply automate this for ya now, wouldn't you??? Sheesh, what a bunch of manual labor Nero makes the user do!!!
Next time, buy the DOWNLOAD online, maybe it saves some time?!-- Geo :: I play ALL my * .AVI files on my Philips DVP642 !!!
No offense but you need to upgrade your PC,a 450MHz CPU and 192 MB of RAM isn't enough to work with video.....not to mention burn DVD's.
What I want to know...is Nero 6.6 as good as Nero 5.5.10.52...Seriously.
Geronimo -
download the latest update and run the update then enter your new registration or go to help and registration and then update.
Try reading the thread originators post..as he's upgraded now!
Did you even read anything but the thread title? -
If I understand that, what you are suggesting is to just ignore the CD-ROM I got in the retail box, instead:INFRATOM wrote :
1. Download Nero install package from the website.
2. Install it, and use the KEY that came in the retail box?
That sounds almost too easy ... too good to be true!?-- Geo :: I play ALL my * .AVI files on my Philips DVP642 !!!
That will work (and is probably the best solution as it will allow a clean install of the latest version).Originally Posted by GeoFan49Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think.
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 20:23 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 22:09 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 12:10 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 06:06
