Anyone know how to convert mono to stero sound in Avisynth?
It would be nice if it is possible to use the same function on a stereo video, and have it remain in stereo.
I can only find Stereo to mono
Thanks for any help in advance
Ok, seem to have found the answer myself
The command MergeChannels can do it.
Just in case anyone else wanted the answer -
IIRC, what you'll be doing will be making MONO-->DUALMONO, NOT MONO-->STEREO.
Stereo includes elements in the mix panned in differing levels across the spread between 2 channels. To do this even half-way correctly ALWAYS requires loading the mono file into a multitrack audio editor and using different segments/frequency bands of (copies of) it and separately panning each. There are obviously more things that can be done, but that is the minimum. If you haven't done that, you're not really doing Mono-->Stereo. It's just not a 1-click process, it's really another form of re-mixing.
If you had a recipe for soup, how would you change the ingredients after it had already been stirred?
Scott -
MonoToStereo(last,last)
or
GetChannel(1,1)
See http://avisynth.org/mediawiki/MonoToStereo
and
http://avisynth.org/mediawiki/GetChannelLast edited by AlanHK; 27th Jul 2011 at 07:03.
Mono to Stereo in MPC?
By jg84 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jan 2012, 12:56 -
Where Can I Buy a mono-stereo 3.5 mm mono to stereo L-adapter?
By solarblast in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 26th Nov 2009, 05:45 -
mono to stereo?
By wingfan in forum AudioReplies: 5Last Post: 22nd Nov 2008, 12:44 -
mono and stereo?
By sharmine in forum Newbie / General discussionsReplies: 9Last Post: 12th Apr 2008, 21:24 -
Mono <-> Pure Stereo
By trolldown in forum AudioReplies: 12Last Post: 27th Aug 2007, 17:12
