Popcorn v1.0.2 released.
http://www.roxio.com/en/support/popcorn/software_updates.jhtml
Highlights:
Tiger compatibility
DVD-R dual layer support
Close Caption and DVD player fixes
AppleScript support
Full notes here
http://www.roxio.com/en/support/popcorn/version_history.jhtml
Results 1 to 15 of 15
is there anything different w/the encoding engine? [i'm still trying to decipher which is better: this or DVD2OneX]
DVD2OneXOriginally Posted by badtz
Popcorn 1.0.2 is about 20% faster then the older version. It does have some changes to the compression to fix some playback problems and closed captions, but besides that I'm not aware of any other changes.
As for DVD2OneX and Popcorn, I would say in most cases that one will not notice any difference in compression quality. DTOX does give more options, but Popcorn can burn and is much easier to use.
Popcorn has been getting much higher reviews then DTOX recently also because it is cheaper. -
Macworld review - they choose Popcorn.
http://www.macworld.com/2005/03/reviews/dvdcopy/index.php -
So is a McDonald's hamburger, but does that mean its a Quality hamburger?Originally Posted by chikanakan
Well, my experiences is that the speed of DTOX and Popcorn are pretty close to the same. Depending on the content, Popcorn can be faster. On other content DTOX is faster.
However, Popcorn 1.0.2 is at least 20% faster then Popcorn 1.0.1 so I would say that Popcorn and DTOX are about the same speed now. -
are there any major features popcorn is missing from dtox?
can you take out audio tracks w/popcorn? [and subtitles]
how about taking out various chapters? -
That bit of arithmetic only works if Popcorn was only 20% slower than dvd2onex to start with. Unfortunately you'd have a hard time convincing some of us (including MacWorld, evidently) that that is actually trueOriginally Posted by chikanakan
I find DTOX's quality far superior.
I did a full disc copy w/ Popcorn of a TV show--only two eps on the disc--and they were jerky and unwatchable.
DTOX was lovely as always. -
820am - Just to let you know this reportedly is fixed in version 1.02: "Resolves an issue with stuttering playback on some set-top DVD players."
Re: jerky playback. Popcorn 1.0.2 version history says:
• Resolves an issue with stuttering playback on some set-top DVD players. -
it seems that popcorn's advantange is it's simplicity and burning integration ..... but the thing is, if it lacks even slight quality w/dtox, I'd rather do it the mtr/dtox/toast way ...... :X
any additional comments on the quality and speed of popcorn [in comparison to dtox]?
PopCorn MKV
By omrish5 in forum Video ConversionReplies: 3Last Post: 13th Jul 2011, 12:30 -
How to disable Microsoft Update, not Windows Update?
By ukb007 in forum ComputerReplies: 17Last Post: 8th May 2011, 16:52 -
Do you prefer fresh popped popcorn or day old popcorn?
By yoda313 in forum PollsReplies: 20Last Post: 14th Jul 2009, 23:16 -
MacTheRipper/Popcorn
By monieeka in forum MacReplies: 3Last Post: 21st Jul 2008, 03:39 -
Roxio Popcorn 3 - HELP?
By jphuber1959 in forum MacReplies: 8Last Post: 2nd Dec 2007, 14:50
