  1. Hi,
    I recently used WINAVI to convert an XviD file to DVD. everything worked fine....the subtitle showed up fine....but the subtitle is a little ahead of the actual dialogue....anyone hve this problem before and knw how to correct it? other than that...greatfast program.
    tnx
    -MooK-
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Are you using the latest version of WinAVI?
    Google is your Friend
    is it ahead if you play with windows media player also?
