Would like to make an Audio Copy of a CD. Have tried different software and different results. Any reecommendations as far as software goes. Thank you.
Results 1 to 11 of 11
What you appear to be asking appears too simple. To make a copy of a CD, you can use any burning program with a disc to disc copy. Audio CDs are not of course copy protected. Perhaps you are asking something else?
what have tried, and what results have you got ?
Nero Express's "Copy Entire Disc" generally works for me, although some discs with multimedia content choke and CloneCD comes through with the goods.If in doubt, Google it. -
It shouldn't really matter what you use. As David K alluded, it's not exactly rocket-science since Audio CDs are not protected or anything.
I must say that I'm interested to hear how you think one is better over the other. Better software (easier to use) ? Better sound quality ? What do you mean by "better" ?If in doubt, Google it. -
Baloney. A digital copy is a clone of the original (assuming everything worked properly).Originally Posted by galehickeyICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Are you saying "copy" when you really mean "encode to mp3"????Originally Posted by galehickey
Is your desired end result a burned Audio CD or files on your hard drive?
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
EAC set up with AccurateRip
Different drives have different error correction capabilities, EAC can be set up to take advantage of/compensate for a specific drives ability to read a disc. A scratched disc may produce pops/clicks in a drive with poor error correction. This should be less of a problem with most newer drives.
EAC allows ripping to a single WAV file, multiple wav files with .CUE sheets, ripping to FLAC/APE/MP3/MPC and other formats (with the proper encoders installed).
EAC is widely regarded as the most accurate tool to produce and exact audio copy (hence the name EAC). It does take a bit of setup to achieve the best results.
If the CD is in good shape, any program that can rip in image file (ISO, NRG (nero), PXI (plextools, plextor drives only), etc.) should meet your needs.Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think.
?!! Exact Audio Copy vs. dBpoweramp !!?
By flashandpan007 in forum AudioReplies: 12Last Post: 1st Jun 2011, 15:21 -
!!! Exact Audio Copy 99,99% enough? Parameters OK?
By flashandpan007 in forum AudioReplies: 14Last Post: 13th Feb 2011, 08:51 -
megui copy audio how ?
By miss in forum Video ConversionReplies: 2Last Post: 3rd Sep 2009, 09:28 -
why i am not able to copy audio cd contents to HDD?
By sumeshkri in forum AudioReplies: 2Last Post: 21st Oct 2008, 23:01 -
MPEG2 - Copy audio channel to other
By Francesc001 in forum EditingReplies: 3Last Post: 15th Jul 2007, 21:43
