  1. the avi is of great quality and sound but when i convert it to mpeg1 no audio, also tried toolame still no audio.. any ideas??thanks in advance
  2. I am having the same problem. I was thinking that maybe it had something to do with XP. Also, TMPEGEnc will crash after it finishes encoding. I wish I had some advice to give. All I can say is that I know what you're dealing with.
    ACQ
  3. well i'm running windows 98se and i've never had this problem before i cant figure this bugger out
  4. maybe it's something to do with the new version of TMPEGEnc??? I haven't the foggiest.
  5. well i've tried the version before the newest one and still nothing??
  6. I was having similar problems trying to convert divx audio to mp2, then I switched to Scmpx external tool in tmpg. Seems to work now. Sometimes I convert to wav, then scmpx>>mp2
  7. Most encoders have trouble using compressed audio as an input, extract the wav with vdub (remember to turn on full processing) and use as a seperate audio source. This should hopefully fix your problem.
