Is that possible ???
MITSUBISHI KAGAKU MEDIA DVD-R 8X
I run the test with DVDInfo and DVD Identifier and I got
- Manufacturer Name : Taiyo Yuden (Corp)
- Manufacturer ID : TYG02
So does it means this DVD-R is a fake ???![]()
It's certainly possible that it's fake. Depending on what brand your burner is, you may be able to do PI/PO tests on your discs. TY almost always has very low PI/PO errors, and fakes will have much worse PI/PO numbers. Also, TY media has serial numbers or something similar stamped on the inner part of the discs, I know that there are some photos of what they look like in a thread on here somewhere.
I'm not that familiar with MCC media, although I thought they only used their own media... -
Verbatim Datalife Pastel discs, sold in the European market, are genuine TY discs. I can't say I've heard of any Mitsubishi-branded discs being TY, but it's certainly possible.
Well, the fact that Verbatim uses other Media code cannot be helped, since Verbatim doesn't have its own media code.
But Mitsubishi has its own, just like Ritek, so i just want to confirm if anyone has ever seen any Mitsubishi branded DVD-R with media code other than MCC. -
Verbatim is a subsidy of Mitsubishi Chemical Corporation, also known as Mitsubishi Kagaku Media.
Regards,
TerminalVeloCDCurrently own:
* ASUS CRW-5232AS 'QuieTrak'
* JLMS XJ-HD165H
* LiteON LTR-32123S, LTR-52327S, SOHR-5238S
* NEC ND-2500A@2510A, ND-3500A, ND-3520A
* Pioneer DVR-107D, DVR-108, DVR-109
Taiyo Yuden cutting back on production of optical media
By Kerry56 in forum MediaReplies: 15Last Post: 12th Oct 2010, 00:14 -
Taiyo Yuden Silver Thermal Lacquer 52X CD-R Media (Value Line)
By mccoady in forum MediaReplies: 14Last Post: 15th Sep 2009, 11:50 -
need opinions on blank media - Verbatim or Taiyo Yuden
By pattirose in forum Newbie / General discussionsReplies: 79Last Post: 14th May 2008, 01:54 -
Problems with Memorex Media. Where to buy Taiyo Yuden?
By John Shumate in forum MediaReplies: 11Last Post: 19th Dec 2007, 13:38 -
Taiyo Yuden 16X Water Shield White Inkjet Hub Printable DVD-R Media
By mn072065 in forum MediaReplies: 66Last Post: 28th Sep 2007, 10:29
