hi![]()
I have been using DVD Lab Pro for a couple of months now, and most of the time it works fine. However suddenly it will not compile anymore.![]()
It doesn't matter what project I try, the compile process will start, and then anywhere from 15 to 60 minutes later, the red status bar will be about 3/4 of the way done, and the the message will say "done".![]()
I don't get it........ I have even tried compiling previously completed projects, and they don't work anymore either.![]()
Has anybody else encountered this? Is it just a crappy program?
If so, does anybody know any other programs that do similar things to DVD Lab Pro?
First thing to do, is reinstall it. There are any number of ways that files can get corrupt on a system.
Have you checked for trojans or viruses lately?
Are there any other programs you have recently installed (especially ones that have something to do with video)?Cheers, Jim
My DVDLab Guides -
MY PC is clean.
I reinstalled DVD Lab Pro, and I havn't installed anything recently.......
Its really weird, the test compile works fine, but I know the movie files are fine, because I tried compiling a DVD that I've burned succesfully in the past. -
as evidenced by looking at the first page of this forum, there are quite a few of us who are having this same problem suddenly.
hopefully someone will come up with an answer (a helpful one) soon. -
I had this happen once, and I cleaned out the workspace folders, and compiled to a completely new folder. I think I also ran a rebuild of the motion menus.
Not sure if that will help, but I never continued to troubleshoot, as doing the above cleared things up...George
[DVD Lab] can not function in the "Compile DVD ..."
By dom61 in forum Authoring (DVD)Replies: 2Last Post: 27th Aug 2011, 11:07 -
DVD Lab Runtime error c++ compile.aux?
By dcook in forum Authoring (DVD)Replies: 10Last Post: 29th Aug 2010, 21:46 -
Dvd Lab Pro 2.5 Pre Verification fails / Compile.aux error
By Ultron in forum Newbie / General discussionsReplies: 3Last Post: 29th Aug 2010, 21:45 -
DVDLab Pro 2 compile issues
By milofhead in forum Authoring (DVD)Replies: 3Last Post: 27th Oct 2008, 23:25 -
DVD-lab pro compile problem
By Sats in forum Authoring (DVD)Replies: 8Last Post: 11th Sep 2007, 15:13
