  1. i made my flash ads in swish max everything looks great when it is in swf but when ever i export it as avi the quality get badd ....andd my add look really badd...?i use corel draw and adobe to improve quality of text and shapes ....buttt the colours get dim ...how can i imrpove quality ....is there any video card or i may purchase better vga??is there any device or vga that can improve quality of my swish made video ...???or is there any way to get the quality of swish files better????i m using 32 mb vga any thing u knw about intro designing plzz do write in ....
    my swish file description .... file size 352*240 exported as uncompressed avi then i made vcd of it ...andd if i use a picture in my add the picture quality is the worst quality ...??
    Apr 2004
    Miskatonic U
    VCD is pretty low resolution and heavily compressed (read low bitrate), so expect it look much worse than your original. When you add images to your swf, what are your compression settings ? Resizing them down to such a small area will also impact them a lot.
    Have you tried an alternate path to to get an avi. If the exported swf looks good, try something like swf2avi (google it) to convert it first.
    This has nothing at all to do with your gfx card, more to do with your process.
    Read my blog here.
  3. plzzz mention any other tool n which i can make quality ads...
