    Mar 2004
    Los Angeles
    Hi, guys!
    I am looking for a program that can easily converts DVD-NTSC to DVD-PAL system without destroying the menus and with the minimum decoding time.
    Thanks.
    Mar 2004
    Los Angeles
    Thanks.
  4. Member daamon's Avatar
    Melbourne, Oz
    Hi van_d_man,
    A lot of new-ish DVD players and TVs in PAL-land are also set up to play NTSC, meaning that you may not need to do anything. Look into this as you may save yourself a lot of time and hassle.
    Sadly for those living in NTSC-land, the opposite generally isn't the case.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
