I used WinAvi to convert a DivX file and then opened the folder I created in DVD Shrink. Everything seemed to be going well as the video was present in the preview window but when I played the dvd in my standalone I got no picture or sound but the dvd was playing because the digital counter was moving normally.
I'm thinking it may be a Disc Region issue as I set WinAvi to convert to NTSC but by default it may be creating NTSC files related to another region code. Has anyone else had this problem and how do I solve it?
I am Jack's medulla oblongata
I've already tried VSO divxtodvd and it couldn't convert the file. WinAvi did convert it as the preview window indicates. My problem is with the authoring of the dvd files it created. Hopefully, someone knowledgeable can help.
I am Jack's medulla oblongata -
i had the same problem but it was with wmv files finally found out i had to dowload microsofts media encoder and index all my files,, dont know if this will help with divx files but its the same exact problem i had with wmv'sOriginally Posted by RottenFoxBreath
Files play fine on my pc with Power DVD and have tried burning with Nero but I get the same results. I know by looking at the dvd that there's information burned to it but when I had a similar problem using VSO, it turned out to be that it had been encoded as PAL and I had to click "force NTSC". The only difference was that as a PAL disc, it played on my standalone player whereas the discs I've done with WinAvi don't show at all.Originally Posted by BaldrickI am Jack's medulla oblongata
Problem solved. turned out I was missing a .dll file in the program.
No sound upon conversion from RMVB to DVD using WinAVI Video Converter
By kris2099 in forum Newbie / General discussionsReplies: 12Last Post: 19th Sep 2010, 16:28 -
Help needed for video conversion : Winavi
By leoboms in forum Newbie / General discussionsReplies: 3Last Post: 24th Jul 2010, 13:48 -
WinAVI conversion problem: SWF to WMV
By Omninescience in forum Video ConversionReplies: 2Last Post: 29th Aug 2008, 12:33 -
Framerate conversion question (AVI --> DVD)
By kmmoore in forum Video ConversionReplies: 3Last Post: 19th Oct 2007, 09:47
