I'm working on a project to make a DVD with the photo's and video from our last group voyage.
I've got like a 30 min video footage, and about 2500 pictures, now I would like to create a DVD which can be played in all normal DVD-players, so you can view the movie on the DVD, but I would also add the photo's to the DVD so you can watch them on your computer (or maybe even on your dvd player if he can read JPEG files)
is this possible?
Any tips/hints are very welcome!
Gery
Yes. Author your disk as normal for the video. Write the results to your hard drive. You should get at least a video_TS folder, and probably an audio_TS folder as well. The audio_TS folder will be empty. That's the way it's meant to be.
At the same level as these folders, create a new folder, called pictures (or data or fred - it doesn't really matter). Put your photos in this folder.
You should now be able to burn the lot to disk as a DVD Video.
I don't know what you burn with, so it may make life harder for you. But it really should be that simple.
Good luck. Let us know how you go.Read my blog here.
Normally I use DVD-lab PRO to author my DVD projects, and Copy to DVD to burn the images, but I was looking in DVD-lab, and the burning facility inside DVD-lab makes it possible to add extra files or folders, exactly what I need.
So I tried it out with a little piece of video and some pictures, and formaated a CD-RW as mini DVD, but my DVD player gives "regio error"
That sounds weird as I looked and the DVD should be region free.
In the computer WinDVD plays the DVD just fine. -
Originally Posted by rumplestiltskin
But I might buy a iBook when I get to college next year -
Use DVDLab Pro, set up the movies as normal, then add a slideshow with your pictures.
Then it will be viewable on standalones, whether they play jpg or not.Cheers, Jim
My DVDLab Guides
Vegas 11, multicamera track only rendering to one video track
By CursedLemon in forum EditingReplies: 0Last Post: 29th Feb 2012, 03:11 -
Audio track shorter than video track in MPEG Video Wizard DVD?
By xxxyyy in forum EditingReplies: 3Last Post: 30th Jan 2011, 13:24 -
How to combine video data and audio data in realtime
By mudassar in forum Video Streaming DownloadingReplies: 0Last Post: 31st Aug 2010, 08:00 -
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 12:25 -
re-encode only video track of Quicktimes but keep audio track untouched
By brennbaer in forum Newbie / General discussionsReplies: 6Last Post: 29th Jul 2007, 08:25
