Would someone please explain to me the differences between Temp folder and Temporary Internet Files folder ?
I went into my Temp folder and found many files (music, pictures, etc.) that I accessed in the past. I thought these files would be stored in Temporary Internet Files folder; and I would use Internet Option tool to delete them.
Is it OK to delete the files in the Temp folder? If so, how do I delete them? I see many useless files in this folder.
Thanks![]()
TEMP folder is temp space for system
TEMP INTERNET is temp space for MS IE browser
Other browsers have CACHE foldersWant my help? Ask here! (not via PM!)
The Temporary Internet Files folder is a cache for Internet Explorer. Whenever it downloads something (html page, image, file) it gets stored here. When the space reaches it's limits, the oldest stuff gets kicked out. When you visit a page, IE first checks to see if you already have this page in the cache, and if so, loads it from there to save time.
The Temp directory is a dumping ground for other processes, such as compressions programs. When you open a zip file, it is temporarily unzipped to the temp directory. It should be cleaned up afterwards, but often isn't. This will be why you see a lot of similar files in the two directories.
You can (and should) regularly delete everything in the temp directories (or get something like ccleaner to do it for you). Teh Temporary Internet Files area can be flushed from within IE's Internet Options, however you will notice that regularly visited sites will be slower on the next visit as you download everything into the cache again.Read my blog here.
The best & safest time to clean out the TEMP directory is right after a fresh boot. If I go deleting files after the PC has been running for a while, I like to leave items in the TEMP directory that have been created since the last time I booted the PC.
Don't forget that a good defrag should also be part of your routine maintenance chores.
Good luck! -
whats with the content.ie5 folder inside the temporary internet files folder?
It's a subdirectory, with multiple folders under it, that IE uses to cache the temp internet files, supposedly for more efficient browsing. On my system (WIN98SE with IE6), all the session cookies are cached under the 'Temp Internet Files' folder, and the actual downloaded files (JPEG's, GIF's, etc.) are cached in the multiple folders under the 'Content.IE5' folder.Originally Posted by lumis
Thank you for your help.
I deleted all "junks" in the Temp folder and saved for myself +250MB.
Have a good weekend. -
well the content ie5 folder how can we delete its contents.will cyberscrub remove em
RipBot264 Temp Folder
By jotpilot in forum Blu-ray RippingReplies: 12Last Post: 11th Jan 2012, 16:45 -
WPDNSE folder inside your system Temp folder????
By MozartMan in forum ComputerReplies: 25Last Post: 27th Mar 2011, 08:35 -
DIKO 2.47 Temp folder problems
By chirayuw in forum Authoring (DVD)Replies: 1Last Post: 6th Jul 2009, 05:26 -
YouTube vids now not showing up in Temporary Internet Files folder...
By brassplyer in forum Video Streaming DownloadingReplies: 4Last Post: 18th Sep 2008, 00:09 -
why can´t find FLVs downloaded by means YOUTUBE on IE7 temp files folder ?
By RonWolpa in forum Newbie / General discussionsReplies: 8Last Post: 8th Jun 2007, 07:16
